Quick question on hood hinge +bolts
I have a quick question, i'm missing the passenger hood hinge for my 95 honda civic ex coupe. I'm about to order from hondaautomotiveparts.com the hood hinge+ bolts. My question is which bolt should i buy for the hinge installation onto the frame. in the diagram it shows 2 different size the 6x12 and the 6x15. thanks.
[Product] [No. Illust.] [Reqd. Qty.]
21142 001 7 CLIP, FUEL PIPE
106218 002 1 HOOD
106219 003 1 HINGE, R. HOOD
106220 004 1 HINGE, L. HOOD
106221 005 1 COWL ASSY., TOP
106223 006 1 LOCK ASSY., HOOD
106224 007 1 WIRE ASSY., HOOD
85126 008 1 COVER, HOOD WIRE
87227 009 1 LEVER ASSY., HOOD WIRE
21152 010 1 GROMMET, HOOD WIRE
106225 011 1 RUBBER, HOOD SEAL
106226 012 1 RUBBER, RR. HOOD SEAL
21158 013 1 STAY, HOOD OPENER
21135 014 1 COVER, CONDENSER
21159 015 2 CUSHION A, HOOD
106228 016 1 COVER, R. HOOD HINGE
106229 017 1 COVER, L. HOOD HINGE
21156 018 2 CUSHION, HOOD No Color
21381 019 4 BOLT-WASHER (6X15)
27281 020 4 BOLT-WASHER (6X12)
21381 020 4 BOLT-WASHER (6X15)
20635 021 3 BOLT-WASHER (6X16) (DACRO COATING)
21164 022 1 HOLDER, ROD
21165 023 7 CLIP, COWL TOP
21139 024 4 CLIP, FENDER (INNER)
21166 025 16 CLIP, RR. HOOD
27306 026 13 CLIP, HOOD SEAL RUBBER
21168 027 1 GROMMET, HOOD STAY
13169 028 2 BOLT-WASHER (6X16)
Modified by 94civicex. at 6:44 PM 6/20/2008
106218 002 1 HOOD
not sure on the thread pitch
take a bolt from the drivers hinge to a hardware store find a nut that fits then find the correct bolt for it, either buy the bolts there or order the correct size from honda
