no 1 cyl tdc
Old Jun 20, 2008 | 05:23 PM
h22a_93accord's Avatar
Default no 1 cyl tdc
how do i make sure my no 1 cly is tdc????
Old Jun 20, 2008 | 05:42 PM
Acidcrakker's Avatar
Default Re: no 1 cyl tdc (h22a_93accord)
Take the dizzy cap off and rotate the crank until the rotar is facing the bottom left. Than double check by looking at the TDC marker in the flywheel through the service hole on the block.
Old Jun 20, 2008 | 06:43 PM
98vtec's Avatar
moderator emeritus
arrows on the cam gears pointing straight up and the markings lined up with each other.
or stick an extension down the cylinder 1 bore and rotate the engine counterclockwise until the piston stops moving up.
Old Jun 20, 2008 | 07:37 PM
m00nr0ck Si's Avatar
Default Re: no 1 cyl tdc (98vtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98vtec &raquo;</TD></TR><TR><TD CLASS="quote">arrows on the cam gears pointing straight up and the markings lined up with each other.
or stick an extension down the cylinder 1 bore and rotate the engine counterclockwise until the piston stops moving up.</TD></TR></TABLE>
^^^Thats how I do it when setting the valve lash....or you can just line the white mark on the flywheel up with the pointer on the block inside the timing window
zsnarl
Jan 27, 2010 07:14 PM
Pman92
May 23, 2007 08:53 AM
skunk2finatic
Dec 29, 2004 03:06 PM
sirminder
May 12, 2003 06:27 AM
LshatchTurbo
Aug 13, 2002 08:10 PM
