Which clutch for d16z6 motor and si cable tranny?
Old Jun 20, 2008 | 03:39 PM
lmananT's Avatar
Default Which clutch for d16z6 motor and si cable tranny?
I'm looking for a new clutch but not sure if I'm supposed to match the clutch with the tranny or the motor?
If it's for the tranny, I have an Si cable tranny not sure from what year. Is there a difference in clutches between the 88-91 si trannys because I noticed 88-89 and 90-91 have different part numbers. How do I find out the year of my tranny? Also, are the civic and crx si trannys different?
thanks for answering my many questions.
Old Jun 20, 2008 | 03:44 PM
guy_from_nerk's Avatar
Default Re: Which clutch for d16z6 motor and si cable tranny? (lmananT)
88 hondas are different due to spline count, you can run a 89-91 clutch on your setup. I had a z6 in my old crx mated up to an crx si transmission and just used an SI clutch
Old Jun 20, 2008 | 04:45 PM
vtecb18c's Avatar
Default Re: Which clutch for d16z6 motor and si cable tranny? (guy_from_nerk)
yea if your not running a lot of hp stick with the oem clutch
Old Jun 20, 2008 | 04:55 PM
lmananT's Avatar
im making about 215whp. im on a xtd stage 3 clutch right now and it barely lasted me less than 2 years. i dont know if oem spec clutches could handle that?
ps. are 88-91 civic and crx trannys the same?
slammedz6ef
Apr 24, 2008 11:26 AM
94_civicEx
Apr 1, 2007 11:05 AM
bigblueandyellow
Oct 21, 2004 06:12 AM
crxdx89
Oct 20, 2004 12:12 AM
s2kkk
Aug 14, 2004 05:57 PM
