low profile tires
Old Jun 20, 2008 | 11:20 AM
sku3397's Avatar
Default low profile tires
alright so i just wanna check myself before i buy. stock tires on a 97 lx are 185 65 14.. if i got 185 60 14.. they would still fit the wheels, correct?
Old Jun 20, 2008 | 12:12 PM
TunerN00b's Avatar
Default Re: low profile tires (sku3397)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sku3397 &raquo;</TD></TR><TR><TD CLASS="quote">alright so i just wanna check myself before i buy. stock tires on a 97 lx are 185 65 14.. if i got 185 60 14.. they would still fit the wheels, correct? </TD></TR></TABLE>
Fit the wheels, yes.
Be the correct size to preserve the speedometer/odometer reading, no.
I wouldn't do it. If you want a lower profile tire, get 15" wheels (or 16s), and run the correct sized tire.
Old Jun 20, 2008 | 03:39 PM
nsxtasy's Avatar
H-T Order of Merit
Default Re: low profile tires (TunerN00b)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TunerN00b &raquo;</TD></TR><TR><TD CLASS="quote">Fit the wheels, yes.
I wouldn't do it. If you want a lower profile tire, get 15" wheels (or 16s), and run the correct sized tire.</TD></TR></TABLE>
Another option is to keep your 14" wheels, but get 195/60-14 tires, which will preserve the speedo/odo accuracy (changing it by 1.1 percent, which is a very small amount). It doesn't change the sidewall height significantly, but it means a wider tire, therefore a lower profile.
If you're looking for a lower sidewall height, though, the way to do it is with bigger diameter wheels, like TunerN00b says.
Chaveli
Jul 31, 2008 02:11 PM
pushinlsteg
Honda Fit
Sep 14, 2006 09:06 PM
ekcivic9
Jun 25, 2005 06:45 PM
JforJonathan
Mar 2, 2005 08:31 AM
D16madwoman
25
Jun 27, 2003 04:53 PM
