94 sideskirts on a 91
I havent tried to modify a 94 sideskirt to a 91. But why wouldnt you just buy sideskirts specific to your 91 accord? - they are like $130 bucks both sides. Or do you already have side skirts from a 94 that you want to fit to your 91? If thats the case, my guess is that they are probably quite interchangeable. The differences between the 94's and 91's are mostly appearance and the engine, but the chassis and chassis components are basically the same.
I just installed a new body kit on my car a week ago, and for the sideskirts i just put them on over the stock black plastic "side skirt" , and drilled holes into the frame from the bottom and installed long screws. I did have to put in about 1 inch plastic spacers between the kit, and the frame to keep the kit at the right angle against the car though.
