help on sohc zc vtec please on 94 ej2
Old Jun 20, 2008 | 10:19 AM
teamrpm2's Avatar
Default help on sohc zc vtec please on 94 ej2
well ma friend bought a 94 ej with a sohc zc engine it had no ecu and the plugs were cut should he get a whole complete wiring harness?? if yes from what engine or what type im not that familiar with zc...and if could he just buy plugs and do some ghetto work to it the only things cut off are the actuall plugs is still has this little black box attach to the wiring harness i believe is obd1 if anyone knows please let me know thanks
Old Jun 20, 2008 | 11:54 AM
teamrpm2's Avatar
Default Re: help on sohc zc vtec please on 94 ej2 (teamrpm2)
ayuda aka help
Old Jun 21, 2008 | 11:02 PM
teamrpm2's Avatar
bump wanna get this car running
Old Jun 22, 2008 | 06:45 PM
teamrpm2's Avatar
help homeboy out lol
Old Jun 22, 2008 | 06:57 PM
averyvm's Avatar
Im not positive about this but I think ZC motors are Dual Over Head Cams. and when it comes to the harness I think you have a couple of options you could buy the connectors and re-pin every wire or you could go ahead and buy a new harness
Old Jun 22, 2008 | 07:03 PM
teamrpm2's Avatar
Default Re: help on sohc zc vtec please on 94 ej2 (averyvm)
well it says zc on the block and the head says vtec so im pretty sure is vtec unless is a z6 head or a y8 head...
Old Jun 23, 2008 | 01:20 AM
teamrpm2's Avatar
still no reasonble answers please help what wiring harness do i get if i buy a new one can i just buy the plugs and color match the wires
Old Jun 23, 2008 | 01:59 AM
vdawg559's Avatar
zc/ came in the 88-91 civic si. i personally have a zc/vtec. on my 92 civic dx. but i usaually they come non vtec.
Old Jun 23, 2008 | 02:16 AM
teamrpm2's Avatar
Default Re: (vdawg559)
so wat obd is it obd1 or obd0??
Old Jun 23, 2008 | 03:59 AM
K20R_EM1's Avatar
Default Re: (teamrpm2)
you got the sohc ZC engine, the car is OBD1 im pretty sure its running on a OBD1 harness, thing is is it vtec or non vtec? if its vtec find a 92-95 civic ex/si and get the harness or plugs, but itll be really confusing because theirs little lines on them.
Old Jun 23, 2008 | 02:01 PM
teamrpm2's Avatar
Default Re: (K20R_EM1)
yeah it is vtec ok so get a harness or plugs from a 92-95 ex or si ok thanks for the help guys i just wanna get this car running will it run good with a p28 virgin???
Old Jun 24, 2008 | 11:59 AM
teamrpm2's Avatar
bump
Old Jun 29, 2008 | 01:06 PM
K20R_EM1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teamrpm2 &raquo;</TD></TR><TR><TD CLASS="quote">yeah it is vtec ok so get a harness or plugs from a 92-95 ex or si ok thanks for the help guys i just wanna get this car running will it run good with a p28 virgin???</TD></TR></TABLE>
yea, it should run almost perfect with a p28 ecu.
Old Jun 29, 2008 | 05:24 PM
coupej1's Avatar
your best bet is to find a 92-95 ex/si and get the whole harness..engine harness and the harness that runs inside to the ecu, also get the ecu out of the same car (p28). i am also running the same sohc zc vtec motor.
99sohczc
Jan 29, 2016 12:56 PM
billy_thekid
Sep 26, 2007 04:54 PM
Idiotboy
27
May 16, 2005 08:21 PM
SIRX
11
Jan 13, 2003 06:29 AM
