6th Gen Lower Tie Bar
Old Jul 17, 2002 | 09:31 PM
Sracer125's Avatar
Default 6th Gen Lower Tie Bar
Does anyone know if there's going to be a Lower Tie Bar available for the 6gens? I can't find it anywhere...
Old Jul 17, 2002 | 09:59 PM
Mike P.'s Avatar
25 Year Member
Default Re: 6th Gen Lower Tie Bar (Sracer125)
It's true...
one must "tie together" thine Accord.
Old Jul 17, 2002 | 10:20 PM
CmptchAV6's Avatar
If i remember the suspension setup in the rear of the 6th gen accords correctly there isnt 2 presise spots that need to be tied together. Multilink double wishbone suspension is much different from the typical suspension honda used in the older accords such as the 5th gen.
Old Jul 18, 2002 | 05:15 AM
Gennady's Avatar
New User
Default Re: 6th Gen Lower Tie Bar (Mike P.)
Old Jul 18, 2002 | 02:56 PM
Sracer125's Avatar
so does that mean that the lower tie bar is unnecessary? Or...its just not worth going to the trouble of making...
Old Jul 18, 2002 | 03:46 PM
CmptchAV6's Avatar
the only reason a lower tie bar would be nessassary is if you put a huge rear sway bar on the car and the stock chasis points were too weak to support it then you would get one that would add aditional support to the sway bar and would tie the sway bar into the stronger mounting points of the suspension. Other than that lower tie bars are pritty much all for show. The lower parts of the suspension are already pritty stiff down there it is up top where they get weak.
Old Jul 18, 2002 | 04:47 PM
Evo_Schen's Avatar
Default Re: 6th Gen Lower Tie Bar (CmptchAV6)
I think I read that neuspeed has a lower tie bar available.
Old Jul 18, 2002 | 06:50 PM
souljad9's Avatar
Default Re: 6th Gen Lower Tie Bar (Evo_Schen)
skunk2 has a lower rear tie bar for the 6th gen.
Ek-Xang
Feb 4, 2010 12:30 AM
GG99
Oct 25, 2005 12:28 AM
[HrZn]4life
Nov 7, 2002 08:26 AM
ZUL8R
Aug 24, 2001 10:05 AM
spoon805
Jul 31, 2001 07:36 AM
