Belt squeal / squeak at startup
Old Jun 20, 2008 | 05:54 AM
integra15's Avatar
Default Belt squeal / squeak at startup
I just changed my accessory belts (PS + alternator). Now when the engine is cold and it starts up, their is a brief squeal / squeak.
What would be most likely to cause the noise, a belt that is too loose, or too tight?
Old Jun 20, 2008 | 09:15 AM
mgags7's Avatar
It could be either one. make sure you get them just right
Honestly though, they should be tight enough to where you can grab an open section of belt and only twist it 90 degrees. No more, no less. You should be fine like that.
Old Jun 20, 2008 | 04:09 PM
spoonfedcrx's Avatar
Default Re: (mgags7)
too loose tighten em up.
Old Jun 21, 2008 | 08:39 PM
prion's Avatar
Default Re: Belt squeal / squeak at startup (integra15)
I've also had shitty quality belts cause the same problem at proper tension. Check your tension and if it's ok, then consider getting better belts. Also, clean the pulleys before putting a new belt on (brakleen or lacquer thinner works ok).
Old Jun 22, 2008 | 12:19 PM
95JDMprelude's Avatar
do u have aftermarket pulleys on the motor??
Old Jun 27, 2008 | 11:26 AM
integra15's Avatar
Default Re: Belt squeal / squeak at startup (95JDMprelude)
Thanks I checked em and they do seem way loose. I'm going back to the shop to have them tighten them up. Too much of a hassle to try yo get to the alternator belt.
Old Jun 27, 2008 | 02:40 PM
greenz95's Avatar
Default Re: (spoonfedcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spoonfedcrx &raquo;</TD></TR><TR><TD CLASS="quote">too loose tighten em up.</TD></TR></TABLE>
x2 i had the same problem, just tighten it up
Old Sep 13, 2008 | 01:34 PM
piggydog's Avatar
Default Re: (greenz95)
how do you tighten it?
supermeister
May 25, 2009 03:09 PM
.Noah Fecks
Feb 8, 2005 12:31 PM
silvercivichatch
Dec 20, 2004 06:45 PM
MrEg
Oct 13, 2003 04:48 PM
cr-x si
Mar 23, 2003 04:43 AM
