Why would a timing belt walk off the cam gears ?
Old Jun 19, 2008 | 10:11 PM
TurboB16A300Hpteg's Avatar
Default Why would a timing belt walk off the cam gears ?
On my integra 4 sum reason the timing belt walks off the Cam gears n starst to run on my valve cover is there anyone out there that can help me think of what it would be and how else o prevent it ??? Thank everyone
Old Jun 20, 2008 | 03:42 AM
mmuller's Avatar
Mad Scientist
Default Re: Why would a timing belt walk off the cam gears ? (TurboB16A300Hpteg)
guide washers in crank pulley missing?
Old Jun 20, 2008 | 12:15 PM
darkdementshun's Avatar
Default Re: Why would a timing belt walk off the cam gears ? (mmuller)
This happened to me when we put the built H22 in my hatchback. We replaced the belt, tensioner, and rechecked everything. Never happened again. Just go over everything with a fine tooth comb. I'm pretty sure mine was tensioner related. (we were trying to re-use the old one that only had a couple oil changes on it.)
Good luck and post up if you find out exactly what it was!
Old Jun 20, 2008 | 04:25 PM
fourthgenhatchB17's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mmuller &raquo;</TD></TR><TR><TD CLASS="quote">guide washers in crank pulley missing?</TD></TR></TABLE>
Old Jun 20, 2008 | 07:45 PM
ivan93egreppin210's Avatar
Default Re: Why would a timing belt walk off the cam gears ? (fourthgenhatchB17)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fourthgenhatchB17 &raquo;</TD></TR><TR><TD CLASS="quote">
</TD></TR></TABLE> x3 i forgot to put mine on as well. no biggie. remove crank pully and put guide on. did mine in 30 mins.
gravity73
Feb 9, 2014 03:05 PM
Rsqd
Oct 11, 2006 06:53 PM
GRAVEDIGGER
Jan 16, 2006 03:46 PM
redlseg
Apr 20, 2005 07:07 PM
