need help suspension?
Old Jun 19, 2008 | 09:56 PM
crbnfibr's Avatar
Default need help suspension?
just bought this 91 si rex....
its no gem but what is for just over a grand....my biggest problem is bad negitive camber on all four wheels however the car is at stock height...so is it bushings or what... its got new front shocks...is it A arm related? just bushings? i dont need to know by tommorrow its just i dont want to be eating through tires....thanks for the help in advance
--crbnfibr
sorry its a repost but no help and i want to get new wheels, and i dont want to do that if they are just going to get eaten up
thanks again
Old Jun 20, 2008 | 03:39 AM
90teg91hatch's Avatar
Default Re: need help suspension? (crbnfibr)
what size are the rims on the car? if they are stock 13, 14... it should have that bad camber...
Old Jun 20, 2008 | 07:48 AM
mike-y's Avatar
Default Re: need help suspension? (90teg91hatch)
rim size does not affect camber.
Take your wheels off and look to see if there is any sort of camber kit on your car. This could be an adjustable upper arm or offset bolts.
Old Jun 20, 2008 | 09:06 AM
Default Re: need help suspension? (mike-y)
rims do so effect camber okay so you put 18" on your car does so effect camber!!!
Old Jun 20, 2008 | 09:59 AM
Jakester9500's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90teg91hatch &raquo;</TD></TR><TR><TD CLASS="quote">rims do so effect camber okay so you put 18" on your car does so effect camber!!! </TD></TR></TABLE>
umm, is this true?
Old Jun 21, 2008 | 11:59 AM
mike-y's Avatar
Default Re: need help suspension? (Jakester9500)
lol No, its not true.
Camber is a function of the suspension. Think about where you camber adjustments are (upper A arm). Camber affects the angle the hub is aligned to, and the wheels bolt to the hub, so the wheel angle matches the hub angle - every wheel you bolt to the hub will match the camber angle the hub is aligned to.
Wheels do not affect camber. But depending on the width and offset, they can affect bumpsteer, and steering feel.
90teg, if you are so sure that wheels change the camber, I'd like to hear you explain how that happens.
HondaCivic2006
Honda Civic (2006 - 2015)
Mar 19, 2009 04:40 AM
dohcnotec
12
Sep 23, 2004 12:50 PM
