oil light comes on then off at 3k?
aiight heres the deal i ran some **** over on the highway roughly 80-90 mph...drove it maybe 1-2 mins after it hit noticed oil spray out the back cut her off and coasted when i got out i looked under the car and oil was spewing out from the pan trashed the oil pan swapped in new pan strainer/pickup thing was a lil bent wasnt bad so didnt swap it out....put in new oil and filter started her up and let her run for roughly 6-8 mins....oil light still on....i drover her around the block to try and build up the pressure oil light goes off around 3-3.5 rpms then comes back on when the rpms drop....any idea? oil pump lock up? sensor wacked out? any help wold be great...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bobjohnson »</TD></TR><TR><TD CLASS="quote">drop the pan again and replace EVERYTHING that was bent/broken/looked wrong.</TD></TR></TABLE>
x2
just wondering, if you had an oil light on, why would you keep running it and then rev it up to see when the light goes out.
I woulda shut her down after 20-30 seconds MAX. But, i try to take good care of stuff.
x2
Im having this same problem. Mine happens when the car gets warmed up then the oil light comes on but only at idle. I just changed the oil pan gasket and there was no metal in the pan, strainer looked alright, no dents in the pan, and just got done changing the sending unit to no avail.
This is a 88 Sedan DX with a b18b swap with a b20 head. Car doesnt make any noises and has no symptoms cept the oil light. Im not willing to drive it till it gets fixed.
Did you see if there was an O-ring between the pickup tube and the oil pump? If you have worn Rod/Main bearings You will hardly get oil pressure. Hook up an oil pressure gauge and get a manual reading.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beige89civic »</TD></TR><TR><TD CLASS="quote">Did you see if there was an O-ring between the pickup tube and the oil pump? </TD></TR></TABLE>
DING DING DING we have a winner. One of the pickup tube to oil pump bolts was loose and there was no gasket whatsoever in there.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beige89civic »</TD></TR><TR><TD CLASS="quote">Nice. Getting good oil pressure again?
Modified by beige89civic at 11:04 AM 8/26/2008</TD></TR></TABLE>
Im waiting on the gasket to get here tomorrow morning then I'll put it back together and see what happens. I also got a pressure gauge so I can watch the pressure instead of relying on an idiot light.
ramz7887
17
Mar 20, 2007 12:07 PM
phatstyles
12
Jun 10, 2005 01:47 AM
