f22b2 swap with h22a vtech
Old Jun 19, 2008 | 08:31 PM
spudgta's Avatar
Default f22b2 swap with h22a vtech
I am currently looking for some help in doing my h22 swap in my 94 accord lx and so far am having no luck. I know someone out there has done this and hopefully will be able to help me. I have the engine, the engine wiring harness all the sensors, and i just ordered an ecu from honda.
Now on the negative side i think i am missing parts of the vtec i really dont know but shouldnt there be some sort of harness from the ecu to the vtec itself or can this be hardwired into the car? What wires will i have to change from the factory harness for the f22 to make the h22 work out. I am beginning to think i would be better with a stand alone system if i cant find the info i need here. Please help me i am lost!!!!!!!!!
Old Jun 19, 2008 | 09:50 PM
Civic_4life's Avatar
Default Re: f22b2 swap with h22a vtech (spudgta)
thre is coupole threads here about it, as far as the wiring harnes, i thinjk u only need to extend the vtec wire and couple sensor wires, otehr than that u can use most of ur accod parts, and try cbtuner.com they have some really good info on accord swaps, look in faq, lots of info, but some of them had no pics..
Old Jun 20, 2008 | 10:09 AM
disboikiet's Avatar
Default Re: f22b2 swap with h22a vtech (Civic_4life)
there are some people that modify their existing harness to run vtec or get the full h22 harness. but it is possible to run vtec stand alone by tapping the vtec solenoid to the ecu, ground wire, and tapping the knock sensor.
Old Jun 20, 2008 | 09:40 PM
HondaccordH22aJdm's Avatar
since ur doing a swap in ur non v motor, u need to run all the wires from the ecu to the motor. nothing with ur wireharness cause its not there, just read about ur ecu and find wat wires u need, and dont forget the knock sensor, if u dont have that then no v tec. GL
tkhang
Aug 31, 2010 03:14 PM
omarisramo
Aug 5, 2008 01:45 PM
bigsh22
Jun 8, 2006 08:33 AM
