whats squeeks when i turn my tires??
Old Jun 19, 2008 | 08:26 PM
cilvia's Avatar
Default whats squeeks when i turn my tires??
something is squeeking everytime i turn my wheels mostly when cold and allready warmed up...even sometimes when i just drive straight...so i dont know if its my power steering or suspensions or axles...can anyone enlighten me with some ideas?? it gets pretty annoying mostly when people watch and stare when i hit a corner from a red light...haha
Old Jun 19, 2008 | 08:31 PM
ke98248's Avatar
Default Re: whats squeeks when i turn my tires?? (cilvia)
I don't mean to be rude, but have you jacked up the car and taken a look around yourself?
Old Jun 19, 2008 | 08:49 PM
count me out's Avatar
* B A N N E D *
sounds like a rack or bushings.
it would help if you said what car.
Old Jun 19, 2008 | 09:01 PM
marks97el's Avatar
If it is a high pitch squealing, i have experience with that. The power steering belt.
Up here in Canada, when it is 25 below and i turn the corner down the street from my house that lovely squeak greets me in the morning. When either the temperature warms up, or the engine for that matter, the squeak is non-existent. And yes, from time to time when i am driving in a straight line the odd squeak will come from under the hood. Nothing too serious unless the belt is badly worn.
Old Jun 20, 2008 | 08:14 AM
Juan_Mitosis's Avatar
I had some metal squeaking, when I would turn the steering wheel from the center position to slightly left and slightly right. I changed the right ball joint, and it was gone. Check ball joints, both lower and upper, if its a squeaking metallic kind of sound. Good luck!
Old Jun 20, 2008 | 08:23 AM
cehcivic15's Avatar
Default Re: (Juan_Mitosis)
yes, check ball joints out, while your under there, check your cv axle boots for cracks, try spinning the tire by hand while its off the ground, any noise, go ahead and check your brakes and any signs of oil leakage while your under there too, i know that has nothing to do with that but while your there, be good to check
Old Jun 21, 2008 | 02:29 AM
cilvia's Avatar
Default Re: (cehcivic15)
im going to check all these stuff tomorrow afternoon hopefully to find some clues...thanks guys
erico9222
Honda Civic (2001 - 2005)
May 16, 2014 05:57 PM
oscarlx
Jun 26, 2012 09:26 AM
KtHaNxBai
Dec 13, 2006 07:53 PM
97CWITR
Feb 15, 2006 07:24 PM
norice
Dec 3, 2001 01:20 PM
