Are 88-91 Rex fender the same?
Old Jun 19, 2008 | 08:05 PM
Jetlag's Avatar
Default Are 88-91 Rex fender the same?
Are the fenders for the CRX the same from 1988-1991? I'm about to pic up a used one and like to
know before hand.
Thanks, Jay
Old Jun 19, 2008 | 08:19 PM
crxfreak1117's Avatar
Default Re: Are 88-91 Rex fender the same? (Jetlag)
yes they are the same as far as the fender goes but the molding is different from the 89-90 but can easily be switched
Old Jun 19, 2008 | 11:51 PM
bobjohnson's Avatar
Default Re: Are 88-91 Rex fender the same? (crxfreak1117)
Im pretty sure the seat for the corner light is different too, when they changed from screws on the outside to screws on the inside.
Old Jun 20, 2008 | 08:35 PM
Default Re: Are 88-91 Rex fender the same? (bobjohnson)
not that i know of there should still be places where u can put the screws if u have a 88-89 crx and bought a 90-91 fender then the holes should still be there if not it wont be nothin to drill 2 little holes for the corner light
Old Jun 22, 2008 | 08:26 AM
GroundZer0 336's Avatar
if you have 88-89 and are putting a 90-91 fender im pretty sure you can take out the plastic clips where the corner light mounts and change them w/ the 89s....im not sure though...the side molding on the 88-89 are thicker too. i think they look different at the headlight too, but that might just be me.
Old Jun 23, 2008 | 09:17 AM
Default Re: Are 88-91 Rex fender the same? (GroundZer0 336)
the fenders from 88-91 are identical except the trim piece which has 2 clips to change out the trim nothin is different where the headlight and corner light is
Old Jun 23, 2008 | 09:37 AM
CRX Toad's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxfreak1117 &raquo;</TD></TR><TR><TD CLASS="quote">the fenders from 88-91 are identical except the trim piece which has 2 clips to change out the trim nothin is different where the headlight and corner light is</TD></TR></TABLE>
The corner lights attach to the head light buckets that is the different in the clips or screws.
RPRacing
Apr 15, 2009 06:54 PM
shokkiz
Jun 11, 2007 04:20 AM
g24jr
Oct 16, 2005 08:48 AM
The Brown Kid
Mar 18, 2002 09:51 PM
