How do you install a Greddy timing belt into a 1997 Honda Prelude?
I'm sorry to ask such an easy install question, but it's my first time working with any belts. So far, I'm thinking I just remove the valve cover and the side covering. Then just slip the belt off and install the new one? Also, if I take the valve cover off, do I need to time my engine?
You'll need to remove the crank pulley so you can pull of the lower timing belt cover. Yes, you will need to time the engine when you put the new belt on. Is this an H22 or H23? I'm not familiar with the preludes, but if this is an H22 you may consider doing the H23 manual tensioner conversion.
fausz
Dec 18, 2004 08:55 PM
