a/c full of freon, a/c clutch comes on but air is not cold, compressor bad?
Old Jun 19, 2008 | 06:01 PM
saveacivic's Avatar
Default a/c full of freon, a/c clutch comes on but air is not cold, compressor bad?
I bought another EF and charged up the a/c with new freon (i do this with all my cars, yes I know how to charge the freon) but the a/c is not cold. The freon is full to spec (not over or under) and when I press the a/c button, the blue light comes on and the compressor clutch turnes on too. It does make a little rattle noise from the compressor when I turn the a/c on so I'm wondering what is wrong. Do I need a new compressor?
Old Jun 19, 2008 | 06:03 PM
traxxasx's Avatar
Default Re: a/c full of freon, a/c clutch comes on but air is not cold, compressor bad? (saveacivic)
If you have freon and the compressor clutch does engage and you hear ratteling i would say its bad.
Old Jun 19, 2008 | 09:27 PM
pimpwagon's Avatar
Default Re: a/c full of freon, a/c clutch comes on but air is not cold, compressor bad? (traxxasx)
clutch might be toast on the compressor.
Old Jun 20, 2008 | 12:35 AM
D16SiHatch's Avatar
Default Re: a/c full of freon, a/c clutch comes on but air is not cold, compressor bad? (pimpwagon)
did you by chance pull a vaccum on the whole system before you filled it? If not you may want to give that a try
Old Jun 20, 2008 | 07:46 AM
wiZCo's Avatar
Stouts 'n' Scotch
Sounds like a death rattle on the compressor.
Old Jun 24, 2008 | 09:21 PM
saveacivic's Avatar
Default Re: (wiZCo)
ok thanks guys, i'll get it rebuilt
USA
May 3, 2019 03:28 AM
yoblocher
Jun 28, 2016 08:33 PM
d-ramey
Acura TSX
May 23, 2014 05:47 PM
DSayavan
Aug 31, 2003 09:14 PM
Old91CivicGuy
Apr 20, 2002 03:37 PM
