help a somewhat new honda enthusiast
alrite.....some idiot welded a 2 inch to small charge pipe for my gsr turbo before asking. caused my headgasket to blow.. internally stock gsr turbo.. headgasket recommendations as far as compression goes? or is oem a good way to go? i plan to build so i want something durable. thanks.
um ok. wha?
stock head gaskets are fine. i think you got another issue. 2" too small how? i cant see what you are talking about.
to get the best information be sure to be percise on your question and or problem.
these guy's around here really know their stuff and need aal your info to hook you up
i dont understand how i wasnt specific. this guy was supposed to call me before any thing regarding my turbo. he didnt and welded to small of a charge pipe and the backpressure blew my head gasket. so im gettin the charge pipe fixed and im wondering what head gasket would be most suitable. oem or upgrade and which way to go as far as compression. if i bumped up a little bit on compression would it be bad in the long run.
yeah it was already moved. and yeah has a b.o.v. im not worried about that. i just want to know if i nudge my compression up or down a little bit from the difference in the thickness of the headgasket will it screw me in the long run. but nvm im just going to go oem. thanks.
HB16A1TURBOT3
Feb 24, 2005 08:35 AM
