h22 having trouble flooring it
Old Jun 19, 2008 | 03:42 PM
h22 kid's Avatar
Default h22 having trouble flooring it
i recently added an h22a swap into my 96 accord from auto to MT and now when i floor it the motor seems like it wants to die.... loses alot of power and have to play with the clutch to get it to run right but even then i still cant floor it! any ideas??
KID
Old Jun 19, 2008 | 06:49 PM
Saosinx's Avatar
Default Re: h22 having trouble flooring it (h22 kid)
what ecu are you running?
Old Jun 19, 2008 | 07:44 PM
h22 kid's Avatar
Default Re: h22 having trouble flooring it (Saosinx)
im running a p13 2w... read alot about these and heard they are pretty much ****.... thinking of getting a p28 but cant get a hold of one.
Old Jun 19, 2008 | 07:49 PM
socialistic's Avatar
I see virgin p28s all over the place for sale. You can also use a p72 which lets you run your secondaries.
JDM or USDM h22a? JDM or USDM p13? Is the motor and ecu OBD-1 or OBD-2? That '96 Accord was OBD-2, wasn't it? Did you use any conversion harnesses?
Need some more detailed info on what's happening, and what setup you're running...so we can better diagnose the problem.
Old Jun 19, 2008 | 08:01 PM
Giant_Bean's Avatar
Default Re: (socialistic)
check your ignition timing. The p13 ecu is the stock ECU, there is nothing wrong with it, as long as you installed everything right, it should run that motor without any problems at all.
Old Jun 19, 2008 | 08:21 PM
h22 kid's Avatar
JDM H22a and JDM ecu... motor is obd-1 and my accord is an obd 1 its a 95 but 96 model and yes i had to use a conversions harness... the only thing is it wont let me floor it... so i had to use my old f22 throttle body on my h22a block cause my h22 TB was screwed up... so now im thinking its my tps and map sensor that doesnt have a wire connect to one another to help regulate the air flow along with fuel...
Old Jun 19, 2008 | 08:22 PM
h22 kid's Avatar
Default Re: (Giant_Bean)
how do i check the ignition timing.... i know my timing is write cause we set it up 15 before TDC....
Old Jun 19, 2008 | 09:50 PM
It might be that F series throttle body you're using.
Switch to an h22a or h23a throttle body, and see if that fixes the problem. See if a friend will let you borrow theirs or something.
I have an h23a throttle body lying around, but a nozzle on the FITV was cracked off...
Old Jun 19, 2008 | 10:00 PM
Hawkze_2.3's Avatar
Yeah, it could definitely be timing. Double check ignition and cam timing.
Old Jun 19, 2008 | 11:19 PM
h22 kid's Avatar
Default Re: h22 having trouble flooring it (Hawkze_2.3)
ok i will check the timing but i dont think the TB could be the problem cause when i had my old H22 TB it had an extreme high idol at 3K rpm and when i put my f TB it dropped to 7/800 RPM so i doubt it may be that!!! but i will check and possibly but an 68 mm H TB upgrade compared to my 60 mm
Old Jun 22, 2008 | 01:18 AM
h22 kid's Avatar
got my check engine light to go off
ej7attack
May 7, 2020 04:39 PM
catchdz
Dec 2, 2011 05:50 PM
accordmatt
Aug 17, 2010 06:24 PM
more3688
Feb 24, 2010 07:38 AM
1.8T_EG
May 6, 2003 09:20 AM
