JDM integra hood latch vs 92-95 civic
Old Jun 19, 2008 | 11:51 AM
qazaq's Avatar
Default JDM integra hood latch vs 92-95 civic
would a hood latch from 92-95 civics fit in place of jdm teg one? from the pictures i can tell that they look identical
can any one confirm?
JDM front latch
92-95 civic latch
Old Jun 20, 2008 | 03:00 AM
qazaq's Avatar
Default Re: JDM integra hood latch vs 92-95 civic (qazaq)
anyone?
Old Jun 20, 2008 | 10:26 AM
Naruto's Avatar
They look similar, but they're not. I noticed the hole for the bolt on the right hand side is a little lower for the teg than it is for the civic. Also, the tab where you have to push to release the hood is different too. Not sure if that will make a difference. It may line up ( I'm guessing ) when bolting it on, but I would either use the actual JDM latch, or if you can find one from a DA.
Old Jun 20, 2008 | 02:23 PM
jjesus's Avatar
try a 90-93 da hood latch i might be wrong put i know a hood release for da works on jdm front (dc2) the cable
Old Jun 20, 2008 | 05:33 PM
typeR#0427's Avatar
Default Re: JDM integra hood latch vs 92-95 civic (jjesus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jjesus &raquo;</TD></TR><TR><TD CLASS="quote">try a 90-93 da hood latch i might be wrong put i know a hood release for da works on jdm front (dc2) the cable </TD></TR></TABLE>
this is correct from my recollection.
Old Jun 20, 2008 | 09:54 PM
Brice.Hayden's Avatar
Default Re: JDM integra hood latch vs 92-95 civic (typeR#0427)
I know for a fact that you can use the civic one. i've seen it and i can verify that it works, I personally kept the JDM one and used a DA cable, but for the EG one it does work
Old Jun 23, 2008 | 05:50 AM
qazaq's Avatar
Default Re: JDM integra hood latch vs 92-95 civic (Brice.Hayden)
the top locking part of the DA lock is a little smaller so it might not grab the hood to close. civic one looks almost identical besides that right hole being a little higher, but that's shouldn't be a problem
i already heard that people use DA cable since it's a little longer so i will probably end up doing the same. ill give it a try with a civic latch
Old Aug 24, 2008 | 06:10 AM
qazaq's Avatar
i would like to announce that USDM DC integra latch fits to a JDM front perfectly fine; one modification has to be made, is to bend the release pedal to the opposite side
d15champ
Paint and Body
Feb 6, 2010 08:28 AM
Green_Goblin
Oct 24, 2008 02:48 PM
98gsrTEG
Nov 25, 2004 06:37 AM
i hav an ef
Sep 5, 2004 02:52 PM
WickedKP
Jul 27, 2003 07:39 PM
