P0135 and P0302 related?
Hi,
I have 97 Honda Accord and my check engine light came on.
I got the following 2 codes:
1) P0135 ( http://www.obd-codes.com/p0135 )
2) P0302 ( http://www.obd-codes.com/p0302 )
I was wondering if it is possible that the P0135 caused P0302 to happen.
When I started the car, the engine light came on. I only drove 10 miles afterward before I checked the error code.
I mean what are the chances that I get another error code within 10 miles of driving?
I was gonna replace the oxygen sensor and as for the P0302 I'm not sure what to do.
I didn't notice anything unusual. Does anyone know what to do?
Thank You
Modified by tom48 at 12:24 PM 6/19/2008
Thank You
I would think not, the P0135 is the heater part of the Oxygen sensor. and I wouldn't think that a cold sensor misreading would cause then a cylinder misfire.
I see. So they seem to be independent.
So what can I do about the cylinder misfire? I was told that I should replace some rubber seals or something (they kinda looked like rings).
The Honda dealer installed new spark plugs and wires + new ignition kit 1500 miles ago as part of a recall. Could that be somewhat related or could I still have warranty on that?
Thank You
Thank You
jayrod7
Jan 21, 2010 01:45 PM
