code 22 help wont go away 94 accord ex with h22 swap
Old Jun 19, 2008 | 06:35 AM
tlmg21700's Avatar
Default code 22 help wont go away 94 accord ex with h22 swap
i got a 94 accord with a 94 h22a1 swap with a code 22 for the vtec oil pressure switch i got good oil pressure so i changed the sensor that i bought brand new from honda took it for a ride and i did the same thing checked all the wiring everything is good what can be my problem?????
Old Jun 19, 2008 | 07:20 AM
GhostAccord's Avatar
Default Re: code 22 help wont go away 94 accord ex with h22 swap (tlmg21700)
Well if you say that you have good oil pressure, VTEC sensor works and all the wires are good. Using the process of elimination, from the info that you have posted, that only leaves the ECU.
What ECU are you using?
Piglet
Aug 13, 2016 02:51 AM
maneedman
Jan 8, 2006 07:26 PM
mdj_ge
Aug 22, 2004 11:02 PM
jaymar88
Apr 21, 2003 04:06 PM
