What is the fastest N/A D16 around here!?
Old Jul 17, 2002 | 07:44 PM
Maxime's Avatar
Default What is the fastest N/A D16 around here!?
I was just wondering what is your setup.
My brother got a 2000 Civic EX (SI in canada) and he is running 15.4 @ 89mph with no tuning! And he still got the stock b-pipe and cat! (He's got an anxle back)
Here is the complete setup!
- AEM Cold air intake with Bypass valve...
-Trottle body 60mm (JDM)...
-Stock Intake Ported...
-Port&Polish stage 2...
-3 angles Valves Job (CNC)...
-Cam COMPCAM stage 1...
-Camgear ALD...
-11.0lbs Flywheel
-ENERGY SUSPENSION Motor Mount Insert...
-MAGNECOR 10mm Plugs wires
-MSD Ignition SCI w/ coil SS Blaster...
-Header Comptech 4-2-1
-Exhaust NAKAYAMA full stainless(Axle-back)...
-Vtec fields (not installed yet)
Old Jul 17, 2002 | 08:08 PM
fcuked's Avatar
Default Re: What is the fastest N/A D16 around here!? (Maxime)
Old Jul 17, 2002 | 08:19 PM
GripFactoR's Avatar
Default Re: What is the fastest N/A D16 around here!? (1.8 HB)
with all that you should be running faster.....
Old Jul 17, 2002 | 08:21 PM
JaeOne3345's Avatar
Default Re: What is the fastest N/A D16 around here!? (VTECxSiR)
exospeedAMcrx is doing 13.6's i believe on slicks..on a stock bottom end..dont sleep on the single slam wonder
Old Jul 17, 2002 | 08:22 PM
ciRcuitJerk's Avatar
jus f0 dekarayshunZ
......nice
Old Jul 17, 2002 | 08:52 PM
madhatch's Avatar
Default Re: What is the fastest N/A D16 around here!? (CiRcUiTsi)
Mistabone is running low 13.s with the Nitrous. mids without it
TEaMxSyNeRgYx001's Avatar
I ran a 14.78 on my 92 Hatch with slicks and 15.01 without. I had:
dc headers
iceman intake
b&m fuel pressure reg
apexi dunk exhuast with no cat
cusco cam gear
underdrive pulley
and 104 octane
this was done at the temple track in texas
Old Jul 18, 2002 | 12:50 AM
madhatch's Avatar
Default Re: What is the fastest N/A D16 around here!? (TEaMxSyNeRgYx001)
This is a site you can pull a lot of info from . They like the d series and Mista Posts a lot. <U></U> http//pub34.ezboard.com bhondaseries
[Modified by madhatch, 9:52 AM 7/18/2002]
Old Jul 18, 2002 | 12:52 AM
bretx0r's Avatar
Default Re: What is the fastest N/A D16 around here!? (madhatch)
I ran 15.6@86 in my 1998 Civic HX with just:
AEM cold air intake
5Zigen Axelback muffler
Generic Short Shifter
Old Jul 18, 2002 | 12:55 AM
Ivan's Avatar
senior gold member
Default Re: What is the fastest N/A D16 around here!? (bretx0r)
I've seen timeslips of 99-00 Si's that couldn't even pull that off.
Old Jul 18, 2002 | 01:39 AM
jarel's Avatar
Default Re: What is the fastest N/A D16 around here!? (JaeOne3345)
ya...exospeed's crx is doing good
Bisi Ezerioha is the fastest sohc...couldn't remember which d-series he was running.
Old Jul 18, 2002 | 02:51 AM
SjCiViCHB's Avatar
Default Re: What is the fastest N/A D16 around here!? (chyknees)
I think he was using the D15B block and the D16 head using some crazy *** compression Hes in the 11s all motor
my friend wit a Si hatch gutted w/ i/h/e got mid 14s.
[Modified by SjCiViCHB, 11:53 AM 7/18/2002]
Old Jul 18, 2002 | 11:01 AM
Maxime's Avatar
Default Re: What is the fastest N/A D16 around here!? (SjCiViCHB)
Yeah im pretty sure there is more into the car but like I said.. it is not tune yet. We need to install his Field Vtec Controller. and he need a better cat along with a 2.25" catback!
We are hoping for 130-135whp! That would be 30whp more then what the car had when it was stock!
Anyway. We will see this saturday im supposed to go racing with him!!!
Im hoping for 14.8-14.9 (with my car)!
[Modified by Maxime, 12:02 PM 7/18/2002]
Old Jul 18, 2002 | 11:21 AM
Looose_R's Avatar
those one guys with teh baby blue crx are running 10s na
Old Jul 18, 2002 | 11:26 AM
sohc_boy's Avatar
Default Re: What is the fastest N/A D16 around here!? (b20bastard)
bizi's in the tens now and his engine is bored and stroked to like 2 liters now.
[Modified by sohc_boy, 3:26 PM 7/18/2002]
Old Jul 18, 2002 | 11:37 AM
ce's Avatar
ce
Default Re: What is the fastest N/A D16 around here!? (sohc_boy)
I did a 15.64 in my 1995 hatch..138 flywheel hp..Mods are I/H/E and took out the seats..
ridin98civic
Aug 17, 2006 02:08 PM
civic919900
May 18, 2005 07:39 PM
landon
Jul 25, 2004 01:09 PM
iperez
Mar 16, 2004 11:52 AM
jg
Jun 18, 2003 06:30 AM
