after 80mph i'm scared..is it just my R or wveryone is the same
Old Jul 17, 2002 | 07:31 PM
GettaluvR's Avatar
New User
Default after 80mph i'm scared..is it just my R or wveryone is the same
it seems like everytime i drove my R on highway as soon as it pass 80mph/120km my steering is kinda out of control, it's kinda shaking left and right, my car is shaking left and right, just a little bit not a lot, and my car is kinda fading away. is it normal ? or... i know ITR is intend to follow the road condition, but this is really scares me. i'm afraid the car is gonna losing control(coz it feels like).. my sterring wheel is really light at high speed which all my friend says it's normal.
just wonder if this is how it should be how do u guys drive more then 100 mph ?
i did tire balance just last week, so nothing wrong with the tires, except three tires went to track once but the right rear is new, for about 5month, never been to track.could this be ??
thx
Old Jul 17, 2002 | 07:34 PM
norice's Avatar
Default Re: after 80mph i'm scared..is it just my R or wveryone is the same (GettaluvR)
You lost a wheel weight.
Big Phat R's Avatar
well if they all were balanced - then that rules out a bent rim.
had an alignment done recently?
Old Jul 17, 2002 | 07:39 PM
GettaluvR's Avatar
New User
Default Re: after 80mph i'm scared..is it just my R or wveryone is the same (norice)
nope just check it all there. even after i balance the tire it still do the same.
i know one of my alignment is off by 0.5 (dont know which one is it, camber or coster)but shop told me it's ok.
Old Jul 17, 2002 | 07:49 PM
Big Phat R's Avatar
you could have a bad tire - are they the stock ones?
Old Jul 17, 2002 | 07:53 PM
mugenintegra16's Avatar
Default Re: after 80mph i'm scared..is it just my R or wveryone is the same (Phat Bastard)
that dosen't happen to me i've hit 150mph with no problems
Old Jul 17, 2002 | 07:55 PM
VTHokie's Avatar
My car is kinda the same way, i have a broken radial belt in one of my tires. Try rotating your tires, and see if there is any difference.
eric
Old Jul 17, 2002 | 07:57 PM
tonydatyga's Avatar
Just to let you guys know, the wheel weights from the factory aren't matched up right usually. Whenever a car comes in for its first service, we always rebalance and over 80% of the wheels don't need as large a weight and in a different position as the stock piece.
Old Jul 17, 2002 | 08:03 PM
GettaluvR's Avatar
New User
three stock come with the car has 15000km on them and been track before one is new with 5000km on it never been track before, the new one is same as stock (brigestone)
Old Jul 17, 2002 | 08:04 PM
GettaluvR's Avatar
New User
Default Re: after 80mph i'm scared..is it just my R or wveryone is the same (VTHokie)
eric
call me a idiot but what is radial belt ?
Old Jul 17, 2002 | 08:21 PM
sackdz's Avatar
eric
Steel belt inside the tire. What you see when you wear your tires "down to the belts"
sack-who sees lots of belts.
Old Jul 17, 2002 | 09:48 PM
Jmm0056's Avatar
Default Re: after 80mph i'm scared..is it just my R or wveryone is the same (sackdz)
nope, my car handles like a dream at 100+, which it sees more often than it should
Old Jul 17, 2002 | 09:58 PM
PYITR821's Avatar
Do you have one new and one old tire up front? If you do put both front tires to the back and the back tires to front. If you have a new and a old tire together especially up front it could screw up your steering just like you described. I have no problems with my R, my steering is smooth at any speed. Give this a try and get back to me.
Old Jul 17, 2002 | 09:59 PM
PYITR821's Avatar
Default Re: after 80mph i'm scared..is it just my R or wveryone is the same (JUNtypeR)
Don't mismatch your tires with one new and one old. Keep tires with similar wear together especially up front.
Old Jul 17, 2002 | 10:37 PM
YelLowITR's Avatar
it happens to my car "only when i have 7.5" that's all, it shoudn't happen with stock rims and tires
Old Jul 17, 2002 | 11:24 PM
SoCal ITR's Avatar
Default Re: after 80mph i'm scared..is it just my R or wveryone is the same (Jmm0056)
Mine too, no problemswhat-so-ever.
Old Jul 17, 2002 | 11:48 PM
kkim's Avatar
are you saying your alignment is within spec? if not, I'd try having it realigned. alignment can make a big difference on handling at high speed.
also, you might want to try checking your steering rack for looseness.. check out this link...
https://honda-tech.com/zerothread?id=192299
good luck.
Old Jul 18, 2002 | 06:14 AM
GettaluvR's Avatar
New User
na i have the new tire at back. dont think it's coz that
Old Jul 18, 2002 | 06:17 AM
GettaluvR's Avatar
New User
Default Re: after 80mph i'm scared..is it just my R or wveryone is the same (kkim)
good luck.
that sounds new to me.. might have it check. but my car only have 15000 km on it tho, dont think it would be this fast to wear out the steering wheel.
i'll try to get some new tires to put on and see, before that i'll just rebalance every tire and redo alignment.
thank you for y'alls help
Old Jul 18, 2002 | 06:19 AM
DutchITR1689's Avatar
If your tires and suspension are OK, remove your P/S. It will give you a much more confident feeling!!!
I didn't have any problems with at 150 mph...
[Modified by DutchITR1689, 4:20 PM 7/18/2002]
Old Jul 18, 2002 | 06:44 AM
newt2's Avatar
INSERT TITLE HERE
25 Year Member
Community Builder
My car's fine till about 135-140, then it still rides smooth but it just feels light like it wants to leave the ground.
Old Jul 18, 2002 | 09:23 AM
BlazinITR's Avatar
New User
Default Re: after 80mph i'm scared..is it just my R or wveryone is the same (newt2)
No!
I love going that Speed of 150!
Cal
Old Jul 18, 2002 | 09:27 AM
Mr.Sha007's Avatar
Default Re: after 80mph i'm scared..is it just my R or wveryone is the same (Blazin ITR)
do you still have the rear wing on?
Old Jul 18, 2002 | 09:34 AM
ILUVTEC's Avatar
Default Re: after 80mph i'm scared..is it just my R or wveryone is the same (Mr.Sha007)
You NEED to have your car re-aligned, get each side as close to spec(and to each other) as possible. The only other thing is that one of your(probably front) tires is unbalanced. I am not saying that it was mounted and balanced uneven/properly, just that the tire itself could have a problem, this does happen sometimes, some tires have manufacturing defects from the factory, its uncommon but does happen and you may get one every now and then. But first try an alignment. Hope this helps
[Modified by ILUVTEC, 6:35 PM 7/18/2002]
Old Jul 18, 2002 | 09:35 AM
jond's Avatar
Same here. Around 140 it starts to get a tad scarry. But anything under 120 or so it feels stable and planted.
2000!!!!!!
[Modified by jond, 1:36 PM 7/18/2002]
