3 puck clutch is it good for everyday car
Old Jun 18, 2008 | 10:37 PM
ishnathan's Avatar
Default 3 puck clutch is it good for everyday car
i bought a stage 2 exedy clutch for my built gsr and it was a 3 puck clutch i was told this was bad for everyday driving and that it doesn't last long, is a 6 puck better my friend told me that my clutch was for the track and not for the street
i just need to know if i bought the wrong one and how much should i sell the clutch plate for
Old Jun 19, 2008 | 06:18 AM
jdmegmong's Avatar
Default Re: 3 puck clutch is it good for everyday car (ishnathan)
An oem itr clutch is perfect for daily driving.
Old Jun 19, 2008 | 07:43 AM
USDM mullet's Avatar
You can use the 3 puck but a 6 puck is way better for everyday driving.
Old Jun 19, 2008 | 09:25 AM
2LEM1's Avatar
I like to party
Community Builder
Community Influencer
Default Re: 3 puck clutch is it good for everyday car (USDM mullet)
And I dislike DDing my ACT hd/ss...
Old Jun 19, 2008 | 09:32 AM
FST GSR 1's Avatar
I use a comp clutch pn#1620, I don't DD the car, but its rough in continual start and stops and it's a 6puck sprung hub design.
I also have a Omni Power Quick clutch master that I believe to be the root cause of the engagement probelms. I'd trade it for a new OEM.
Old Jun 19, 2008 | 06:17 PM
NAH2B's Avatar
Default Re: (FST GSR 1)
the 3 puck exedy is fine for everyday driving as long as its the thick disk and NOT the thin disk
the pads on the thin disk tend to break apart easily.
Old Jun 21, 2008 | 04:50 PM
slambedcivic's Avatar
Default Re: (NAH2B)
i had a exedy cermetallic thick disc setup. ls turbo, gsr trans. drove it for a year and a half before i replaced it. DDed and raced... i have a stage 5 clutchmasters unsprung hub 6 puck that i drive on the street now.
Old Jun 21, 2008 | 05:49 PM
Fat Chick Magnet's Avatar
exedy stage 1 is cool for daily driving. even stage 2 as long as its full disk and no chattering then its sweet for daily driving IMO
Old Jun 21, 2008 | 06:08 PM
Default Re: (Fat Chick Magnet)
exedy doesnt have "stages" but different levels of clutchs. their so called "stage 2" is a cermetallic 3 puck disc. it will only come is two different variation. thin and thick discs.
Old Jun 22, 2008 | 08:54 AM
ishnathan's Avatar
Default Re: (slambedcivic)
well i got a exedy 3puck (thick) and i need to know if its any good
Old Jun 22, 2008 | 09:50 AM
formby's Avatar
i used a thick 3puck sprung clutch from exedy intil just recently. worked great
i like my new CC 6puck sprung unit a lot better
the 3 puck feels like it grabbed harder but the 6 puck is better when DD light to light.
Old Jun 22, 2008 | 11:47 AM
Default Re: (ishnathan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ishnathan &raquo;</TD></TR><TR><TD CLASS="quote">well i got a exedy 3puck (thick) and i need to know if its any good</TD></TR></TABLE>
yes, you will be just fine.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by formby &raquo;</TD></TR><TR><TD CLASS="quote">the 3 puck feels like it grabbed harder but the 6 puck is better when DD light to light.</TD></TR></TABLE>
i totally agree. i had a CM stage 4 sprung hub 6 puck in my dc2 and it was a DD. my "track car" has a CM stage 5 6 puck unsprung hub and i do drive it on the street every now and again
Old Jun 22, 2008 | 12:31 PM
anothersickhatch's Avatar
i daily drive my car with the same clutch and its just fine. i pulled the tranny after about 10k miles and there was still a whole lot of clutch life left.
its a little tricky to get used to, but once you do, you'll be fine for daily driving.
Old Jun 22, 2008 | 03:53 PM
ishnathan's Avatar
Default Re: (anothersickhatch)
that sounds good i was worried for a moment but ya just one last question with the exedy 3puck stage would i be [freak]ing up my tranny on the track
Old Jun 22, 2008 | 05:51 PM
a "pucked" clutch can shock the transmission's gears if you shift very hard and dump the clutch at high rpms. (i recommend preloading to prevent this shock from a stop) other than that you should be fine. like i said, i raced mine for quite some time and had no trans issues
Old Jun 22, 2008 | 08:38 PM
ishnathan's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slambedcivic &raquo;</TD></TR><TR><TD CLASS="quote">a "pucked" clutch can shock the transmission's gears if you shift very hard and dump the clutch at high rpms. (i recommend preloading to prevent this shock from a stop) other than that you should be fine. like i said, i raced mine for quite some time and had no trans issues</TD></TR></TABLE>
what do you mean preload
Old Jun 23, 2008 | 02:51 AM
using the hand brake to hold the car at the line and releasing the clutch until it grabs and then getting up to the launching rpm that you want.
pretty much "slipping" the clutch at the line.
Old Jun 23, 2008 | 08:57 AM
Aquafina's Avatar
Daily driven on an Action Clutch 1MD (6-puck unsprung). Used to be on the 1MS (6-puck sprung). No problems with either, even when used with the Omni CMC.
Old Jun 23, 2008 | 11:15 AM
2stepEK's Avatar
Former Vendor
Default Re: (Aquafina)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Aquafina &raquo;</TD></TR><TR><TD CLASS="quote">Daily driven on an Action Clutch 1MD (6-puck unsprung). Used to be on the 1MS (6-puck sprung). No problems with either, even when used with the Omni CMC.</TD></TR></TABLE>
Btoh are very easy to daily drive.
Old Jun 23, 2008 | 05:22 PM
Aquafina's Avatar
People who haven't driven them don't know that though. Too bad the CMC is discontinued.
Old Jun 24, 2008 | 04:06 AM
FST GSR 1's Avatar
There's a reason the CMC is discontinued. It would be fine in a race car.
Old Jun 25, 2008 | 11:50 AM
Aquafina's Avatar
The reason is because they kept failing. I tested the revised version for Steve and it failed. Worked perfectly fine for my street/track car.
Old Jun 25, 2008 | 03:00 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Aquafina &raquo;</TD></TR><TR><TD CLASS="quote">The reason is because they kept failing. I tested the revised version for Steve and it failed. Worked perfectly fine for my street/track car.</TD></TR></TABLE>
if it failed, how did it work perfectly fine for your street/track car? i may have missed something. lol
Old Jun 25, 2008 | 03:30 PM
99hondacura's Avatar
From: down the street,bythe river in the van, co, united states
i have a act 6 puck sprung clutch on my built ls/vtec i daily drive it everyday for the past year and a half and it holds up pretty good can get annoying in traffic though gets hard when you stop and go lol.. hope this helps!!
Old Jun 29, 2008 | 03:36 PM
Aquafina's Avatar
if it failed, how did it work perfectly fine for your street/track car? i may have missed something. lol</TD></TR></TABLE>
lol
I meant being driveable. A day to get used to it then its invisible. When it was still being sold, a lot of people complained about it for daily driving.
taffetawhitegsr
Aug 24, 2004 06:16 PM
JFG Kevin
Apr 27, 2004 01:49 AM
SoSoJeff
Apr 26, 2003 02:40 PM
ahead
Nov 18, 2002 02:59 PM
