Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
Honda Pilot rear differential question
Old Jun 18, 2008 | 10:32 PM
jimmy408's Avatar
Default Honda Pilot rear differential question
Not too many pilot posts here but I'll give it a shot. Can anyone tell me how to change the rear differential fluid on a 2007 pilot?
Old Jun 19, 2008 | 12:36 PM
nukem384's Avatar
Default Re: Honda Pilot rear differential question (jimmy408)
it's a pretty easy change. if you go onto hondapilot.org, in the maintenance section, there's a how to with pictures. ill tell you how to do it anyways though...jack up the car back AND front so the car is level off the ground.
1. remove the fill bolt first (with a 3/8" extension, located almost directly above the drain bolt (to make sure you can refill your fluid before you empty it out of the dif.).
2. remove the drain bolt (i believe it's also 3/8" extension) and let drain, then re install the drain bolt.
3. replenish your fluid (1 gallon genuine Honda VTM-4 is enough). Since the fill hole is at a weird angle, i use a turkey baster to get the fluid in there.
hope that helps.
Old Jun 19, 2008 | 10:29 PM
jimmy408's Avatar
Default Re: Honda Pilot rear differential question (nukem384)
nukem384,
Thanks for replying to my post. The howto thread on hondapilot.org is very helpful. I think I will change the diff fluid this weekend.
Old Sep 10, 2008 | 05:15 PM
extream_86's Avatar
make sure you use factory fluid or it will ruin your rear diff. NOT COOL!!
Old Sep 11, 2008 | 05:39 AM
Ross 2.0's Avatar
In a Junkyard near you.
Default Re: Honda Pilot rear differential question (extream_86)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by extream_86 &raquo;</TD></TR><TR><TD CLASS="quote">make sure you use factory fluid or it will ruin your rear diff. NOT COOL!!</TD></TR></TABLE>
I get your point but the pilot doesn't have an actual differential. Just clearing up a misconception.
Old Sep 11, 2008 | 07:48 AM
DaiJekBok's Avatar
Default Re: Honda Pilot rear differential question (Ross 2.0)
It's not a traditional differential but its function is that of a differential so I don't see why the term wouldn't apply.
Pilot King
May 21, 2011 04:31 PM
IntegR
Dec 23, 2006 09:11 AM
Too_Funny
Nov 8, 2002 03:34 PM
briq4
May 23, 2002 05:29 PM
