Car died, wont start back up, no spark
Old Jun 18, 2008 | 07:44 PM
mnskateboarder's Avatar
Default Car died, wont start back up, no spark
Had the car idlieing, pull the plug wire from each plug, one at a time, i was checking to see if there was a change in idle, just checking to see if everything was good i guess, but anyway. I got to cylinder #3, and as I was putting the wire back on the plug, it died. Now It cranks and cranks, but wont start.
When holding the plug wire to the plug I couldnt see or hear any sparking. Fuel pump is turning on. Lights, radio, etc work. This is a bseries in a civic. Obd2 harness converted to obd1 engine/ecu. Car has ran perfect since the swap a few months back. Timing belt/cam gears are all lined up fine.
Bad distributor? is there anything to check for to see if it is a bad distributor, or any other ideas? I dont know why it would just die like this, its never done it before.
Old Jun 19, 2008 | 09:18 AM
david974's Avatar
Default Re: Car died, wont start back up, no spark (mnskateboarder)
i think you blowed your coil
you should never disconnect a spark plug wire when engine runing it's very bad for the coil
regards
Old Jun 19, 2008 | 06:15 PM
yeah, somebody else thought it was the coil too. I am going to be replacing that Friday, hopefully that fixes it, if not, is there anything else possible it could be?
Old Jun 20, 2008 | 04:58 AM
nasteawhun's Avatar
it might be your igniter chip, its in the dizzy. if you take a part the dizzy. its a flat looking piece where all the wires are plug into. oh did you check the coil fuse under the dash?
Old Jun 20, 2008 | 11:52 AM
well i put in a new coil and it started right up. Thanks to the 1 reply for the help, and thanks for looking ^
jakescakesz06
Jan 4, 2016 09:38 AM
mr_munro
Jul 25, 2012 10:43 PM
Mechatronics
Jul 23, 2009 01:36 PM
andrew714
Dec 13, 2007 09:35 PM
94GsRacer
Jan 14, 2003 06:39 AM
