Bad Alternator = Misfiring?
Old Jun 18, 2008 | 11:12 AM
Thatssojdm's Avatar
Default Bad Alternator = Misfiring?
ok i just got my alternator tested because iv been misfiring alot and it turned out to be bad. could that cause it?
Old Jun 18, 2008 | 11:19 AM
Acidcrakker's Avatar
Default Re: Bad Alternator = Misfiring? (Thatssojdm)
Probally not.
Old Jun 18, 2008 | 11:20 AM
Thatssojdm's Avatar
Default Re: Bad Alternator = Misfiring? (Acidcrakker)
why not?
Old Jun 18, 2008 | 11:48 AM
Because, hows that for an awnser?
Yout altenator runs your car at 14.2 volts.
If your altentor is bad it will charge at at a lower voltage, or produce lower amps.
H23 alt-80amps
H22 alt-90amps
Bad altenator produces lower amps, nothing to do with spark, unless your alt isnt even producing enough volts to run the car, even so the motor should complete your combustion cycle until your battery is dead.
No sir, I think your problem lies else where.
ECU-Coil-Ignitor-Rotor-Cap-Wires-Plugs
Thats the chain of command in your car that creats your spark, your problem lies in there.
Old Jul 22, 2008 | 01:55 PM
crexer's Avatar
my battery went dead today just died immediately and wouldnt do anything after turning the car off and back on, got jumped off and it was misfiring all the way home.. im kinda having the same issues as well. It just seems weird that the car would die from a dead battery and misfire like that. The "misfire" would trigger the CEL light and the car would jump for just a split second and then be fine...
Old Jul 22, 2008 | 02:23 PM
Keith's Avatar
I've had a bad alternator which cause the car to 'misfire' or buck while I was under WOT... it just didn't have enough juice to keep up with the demand...
Keith
mytest23
24
May 6, 2015 07:29 AM
blue_hatch
Jul 12, 2007 05:30 PM
EG6R
May 10, 2007 01:57 PM
Keith
Apr 5, 2005 09:43 PM
