D16a6/ Skunk2 IM / stock battery location....what intake?
Old Jun 18, 2008 | 09:37 AM
busychild's Avatar
Default D16a6/ Skunk2 IM / stock battery location....what intake?
I have a generic d16a6 2.25 intake tube without a filter right now. looking to get a decent intake/filter setup. would like 3in intake as opposed to the 2.25 I have now.
I am open to:
-buy used or new
-buy one made from another car
-re-dyno after I get my stepped header
see Bio for motor setup.
Thanks in advance.
BTW, I like this stock look setup, if it is more functional over aftermarket.
see bottom pic here:
https://honda-tech.com/zerothread?id=2253109
Old Jun 18, 2008 | 01:35 PM
BiG Chris's Avatar
Weapon-r has 3" intake pipes for the EF
Old Jun 18, 2008 | 04:10 PM
661rex89si's Avatar
2.5 pipping is enough
Old Jun 20, 2008 | 09:56 AM
busychild's Avatar
Default Re: (661rex89si)
Anyone use ITG.com filters for SRI or CAI systems? (not ITBs)
Old Jun 20, 2008 | 12:40 PM
thesmogman's Avatar
Default Re: (busychild)
Here is my set-up on my A6
The tube is for a prelude that I got from Kragen. Then I visited the turbo shop and got the 45deg. tube and the air horn w/filter.
I have positioned the battery toward the motor with a piece of tubing 1/2 fuel tubing so the battery sits a little over to give it more room. Also note the cover on the positive batt. terminal.(Very important)
I can give you the shops name if you need. I was just showing you this so you can get an idea.
Old Jun 20, 2008 | 06:08 PM
busychild's Avatar
Default Re: (thesmogman)
nice engine bay
I will use the positive battery terminal cover and an ITG filter sock to a 2.25 in ebay knockoff tube. the sock is for a 3" tube, but will work for now till I can get a 3" tube cheap.
Thanks everyone for the help.
potatostix
Oct 14, 2009 03:55 PM
MG-EP3
22
Sep 1, 2009 10:00 AM
dreamreaperx
Feb 8, 2007 10:57 PM
eda6
18
Aug 27, 2004 08:55 AM
integraGSR1
Mar 19, 2004 02:11 PM
