Forced Induction Everything Forced Induction (Ex: Turbo Kits, Intercoolers, Blowoff valves, IC Piping, Turbo Manifolds)
AEM EVERYTHING!- Water/Meth Injection, Wb02, Boost Controller, Gauges-Boost/ Oil Water Temp/Pressur
Old Jun 18, 2008 | 08:35 AM
project dc2's Avatar
Default AEM EVERYTHING!- Water/Meth Injection, Wb02, Boost Controller, Gauges-Boost/ Oil Water Temp/Pressur
AEM Uego Wideband
(Part Number: 30-4100).
Using a wideband o2 sensor is the only real way to accurately monitor your air fuel ratio. Monitoring your air fuel ratio is the most important thing when making sure your car is tuned and runing safely and to its full potential. The AEM Wideband is one of the best and most trusted widebands on the market, it comes with a bosch wideband sensor and the trusty aem wideband controller. This fits in a standard 52mm gauge so you can install it in a gauge pod, or anywhere else for that matter.
* Gives a Steady Reading, not a sweeping back and forth like a narrowband gauge
* Standalone gauge, no computer or software is required
* comes with Bosch o2 Sensor
* 0.1 AFR Unit of Measure
* Can be switch from AFR to Lambda
<FONT COLOR="red"><FONT SIZE="4">Price=240$ Shipped</FONT></FONT>
The AEM Water Injection Kit is a safe and economical way to reduce air inlet temperatures to increase boost pressure for more power in your vehicle.
Lower air inlet temperatures allow users to advance timing without having to run higher-octane fuel. This is the most complete kit available on the market straight out of the box- no additional parts required.
AEM 30-3000 WATER INJECTION KEY FEATURES:
• Includes everything you need for installation
• Progressive, controller-driven 150 PSI pump
• One-gallon tank with integral fluid level sensor
• Dash light for system status and low fluid warning
• Alcohol Compatible (up to 50% in solution with water)
• Progressive controller, provides boost-dependent
variable flow
• Output provided to either decrease timing or boost if the system runs out of fluid or detects an error
• Includes three jets to match your power requirement
Fits: universal
<FONT COLOR="red"><FONT SIZE="4">Price=375$ Shipped</FONT></FONT>
AEM’s TRU-BOOST Gauge-Type Controller is an electronic boost controller that combines the simplicity of a manual boost controller with the added ease of adjusting boost levels through a gauge interface. There is no external interface required for set up, and it is fully functional right out of the box. There are no gimmicks or special software programs included. If you want more boost press the button on the right of the gauge face, and if you want less boost press the button on the left of the gauge face. It’s that simple, and IT WORKS!
AEM’s TRU-BOOST Gauge-Type Controller includes everything you need, including an on-board 29 psi pressure sensor, built-in Overboost protection with two timed shutdown levels, a scramble boost setting and a low-side output for a warning light. AEM offers a 75 psi boost sensor for high boost applications (sold separately).
AEM’s boost control solenoid (included) is the only one specifically manufactured for automotive boost applications, which means it won’t corrode and stick from exposure to rich fuel mixtures, it is pressure tested to 100 psi and includes -4 AN fittings to eliminate any chance of leaks.
# No external interface required for programming!
# Complete system includes harness, boost hose, on-board 29 psig pressure sensor (external 75 psia optional), boost solenoid, gauge display and all necessary fittings
# Quick connect technology eases the installation process
# Two user selectable boost settings with peak boost memory
# Scramble boost setting allows user to momentarily change boost levels
# User selectable Overboost alarm includes two timed shutdown levels at 10% and 20% Overboost
# User configurable gauge includes 24 scalable LEDs, and interchangeable bezel, pin guide and faceplate to customize look of display
# One (1) low-side output included for warning lights
<FONT COLOR="red"><FONT SIZE="4">Price=275$ Shipped</FONT></FONT>
AEM’s digital Boost display gauge delivers unsurpassed accuracy and visibility. Each gauge includes 24 color-coded (Red, Green, Yellow) LED lights that change from green to yellow to red for immediate reference to the measured parameter, and an integrated thee-digit display that reveals real-time operating conditions.
AEM’s digital display gauges feature a standard 52mm gauge housing that fits in most gauge pods and can be remotely mounted virtually anywhere. Each gauge includes interchangeable silver and black bezels and black and white faceplates to personalize the look of your gauge—it’s like having four gauge designs in one!
-Gauge pressure range -30-35psi and -30-50psi
-Includes easy-to-install harness and sensor
-Complete stand alone gauge requires no additional sensors or programs to operate
-Ideal for both fuel injected and carbureted motors
-LED displays provide precise reference to critical operating conditions and alert driver of potentially damaging operating conditions
-Includes 0-5V analog output for routing to engine management system or data logger
-Easy to read faceplates/displays are designed to complement existing AEM gauge styles
-Included bezels and face plates allow you to personalize the look of your gauge
<FONT COLOR="red"><FONT SIZE="4">Price=215$ Shipped</FONT></FONT>
AEM’s digital 4-in-1 Oil/Water/Transmission temperature
Universal gauge standalone gauge - no laptop or AEM EMS required to operate!
Part# 30-4402
<FONT COLOR="red"><FONT SIZE="4">Price=148$ Shipped</FONT></FONT>
[b]AEM’s digital 4-in-1 Oil & Fuel Pressure display gauge [b]
Part# 30-4401
<FONT COLOR="red"><FONT SIZE="4">Price=198$ Shipped</FONT></FONT>
<u><FONT SIZE="4"><FONT COLOR="purple">How to order: </FONT></FONT></u>
[b]<FONT COLOR="blue"><FONT SIZE="3">Payment Options: </FONT></FONT>
Paypal---Google Checkout --Money Order/Check/Cashiers Check.
<FONT COLOR="green">Paypal id:</FONT> Racerswholesale@gmail.com
<FONT COLOR="green">GoogleCheckout Id: </FONT>SPoolindevelopment@gmail.com
<FONT COLOR="red">call 408.515.4296 for Visa/Mastercard </FONT>
<FONT COLOR="blue">Mailing Address:</FONT>
SpoolinPerformance
47000 Warm Springs Blvd, STE 224
Fremont, CA 94539
<FONT COLOR="blue"> Local Pick up:</FONT>
Spoolin/Redzone Performance
43257 Osgood Rd
Fremont, CA 94539
Old Jun 18, 2008 | 02:00 PM
Default Re: AEM EVERYTHING!- Water/Meth Injection, Wb02, Boost Controller, Gauges-Boost/ Oil Water Temp/Pre
ttttttttttttttt
Old Jun 19, 2008 | 06:49 AM
Old Jun 19, 2008 | 02:47 PM
ttttttttttttt
Old Jun 20, 2008 | 06:25 AM
morning
Old Jun 20, 2008 | 07:47 PM
ttttttttt
Old Jun 21, 2008 | 10:54 AM
Old Jun 22, 2008 | 07:37 AM
ttttttttt
Old Jun 23, 2008 | 06:56 AM
tttttttttttt
Old Jun 23, 2008 | 06:57 AM
tttttttttttt
Old Jun 23, 2008 | 11:31 PM
tttttttttttttt
Old Jun 24, 2008 | 10:26 AM
tttttttttttt
Old Jun 24, 2008 | 11:11 PM
tttttttt
Old Jun 25, 2008 | 10:31 AM
ttttttttttttttttttttttt
Old Jun 25, 2008 | 10:42 AM
EfGirl's Avatar
Old Jun 26, 2008 | 07:05 AM
ttttttt
Old Jun 26, 2008 | 06:11 PM
tttttttt
Old Jun 27, 2008 | 07:38 AM
tttttttt
Old Jun 28, 2008 | 10:24 AM
tttt
Old Jun 29, 2008 | 11:14 AM
ttttttttttt
Old Jun 30, 2008 | 09:35 AM
tttttttttttt
Old Jun 30, 2008 | 03:29 PM
tttttttttttttttt
Old Jun 30, 2008 | 10:09 PM
t t
Old Jun 30, 2008 | 10:10 PM
t t
Old Jul 1, 2008 | 05:25 PM
tttttttttttt
