idling problem with gsr swap EG
Old Jun 18, 2008 | 06:20 AM
60019184's Avatar
Default idling problem with gsr swap EG
so i fitted a b18c4 along with a s21 gearbox but the are a few problems;
1) when starting up cold, the revs sit at just under 1k. Isnt it meant to be higher when cold - what the fitv does? but the engine doesnt have a fitv
2) when starting up warm, the revs jump between 300 to 700, so not they're not consistant
3) sometimes when pulling up and/or slowing for a junction it just turns completely off
4) oil pressure light stays on but goes off when i give it a slight rev, could this be because of using a D16Z6 vtec solenoid?
Old Jun 18, 2008 | 09:57 AM
60019184's Avatar
bump
Old Jun 18, 2008 | 03:50 PM
vtecb18c's Avatar
Default Re: idling problem with gsr swap EG (60019184)
sounds like your tps
Old Jun 20, 2008 | 05:10 AM
60019184's Avatar
could it be the loom or the distributor?
Old Jun 20, 2008 | 07:36 AM
instrument's Avatar
http://www.team-integra.net/fo...Topic
Old Jun 20, 2008 | 09:26 AM
cehcivic15's Avatar
Default Re: (instrument)
make sure you didnt mix up the connectors for the tps and the map cuz they are the same, check those two
Old Jun 20, 2008 | 04:08 PM
60019184's Avatar
how can i check if its the right connectors?
please help
pollito1320
Nov 26, 2011 06:41 AM
dc2much
Mar 17, 2010 07:19 PM
turboeg831
Mar 8, 2008 04:31 PM
h22aCb7
Oct 2, 2007 09:00 PM
jskb4eva
Aug 1, 2007 09:23 PM
