Lighting HID/Xenon kits, Retrofits and Associated Topics
2008 Accord Coupe HID Question...
Old Jun 17, 2008 | 11:57 PM
iron312's Avatar
Default 2008 Accord Coupe HID Question...
Sup Guys, I have a 08 accord coupe it has projectors on it but the lights aren't HID like.
So my question is do I need to get the whole HID kit or just the bulb?
Old Jun 18, 2008 | 01:32 PM
TunerN00b's Avatar
Default Re: 2008 Accord Coupe HID Question... (iron312)
You should do a proper retro-fit of the entire optics from a factory HID equipped car. This means projectors, shields, ballasts, and capsules.
Lacking that, as a fellow CA driver, I strongly request that you do NOT install a "HID kit". I am completely fed up with being blinded by asshats running HID capsules (HID does not use a "bulb", there is no filament) in headlights designed for the output of a halogen bulb.
Old Jun 18, 2008 | 10:21 PM
iron312's Avatar
Default Re: 2008 Accord Coupe HID Question... (TunerN00b)
what is a retro fit mean? the car already has projectors headlights...
Old Jun 19, 2008 | 08:28 AM
prelude1897's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iron312 &raquo;</TD></TR><TR><TD CLASS="quote">what is a retro fit mean? the car already has projectors headlights...</TD></TR></TABLE>
it means you take HID projectors from one car such as TSX, BMW, Mercedes, ect. ect. and put them into headlights that don't have them. As for your car, the projectors you have are meant for halogen lighting, so if you want the best light output for your money, then I'd suggest replacing your current projectors with HID projectors
Old Jun 20, 2008 | 08:48 PM
AznX TL's Avatar
actually the projectors on the accord coupe handle aftermarket hid kits VERY nicely.
but yes, get a pnp hid kit. you'll need h11 bulbs.
Old Jun 22, 2008 | 07:08 AM
retrosolutions's Avatar
I'll second that, we have many 08 Accord customers. The projectors work very well with HID pnp, well at least with our kits, not sure about others with different focal points.
Old Jun 22, 2008 | 04:22 PM
TunerN00b's Avatar
Default Re: 2008 Accord Coupe HID Question... (AznX TL)
The cutoff is good on those shots.
However, the problem with HID in halogen lights (even projectors) is spread. The 3200 lumen output from a HID capsule is significantly brighter than the 1200 lumen output of a 9006 halogen bulb, and that extra light projected over the same area is wasted.
To use the brighter HID output, you need a wider beam pattern. Anything else, is just wasted foreground lighting, and actually hurts your ability to see past the headlamp limit.
Old Jun 23, 2008 | 01:10 PM
striker_18's Avatar
Accord projectors are the same as the MDX halogen ones. No width but intensity is okay but at least there are barely any hot spots.
Just because something has projectors doesn't mean it is meant for HID's.
BTW, the pictures above, intensity looks good because the owner has HIDs in his low beams and fogs <u>AND</u> both of them are on.
Old Jun 23, 2008 | 11:04 PM
iron312's Avatar
Default Re: 2008 Accord Coupe HID Question... (striker_18)
it doesnt look like his fog lights are HIDs...
Does anyone know where to get a retrofit done in cali?
Old Jun 24, 2008 | 04:10 AM
Genuine Rolla's Avatar
What color did you go with..?
Brain'Z
Mar 27, 2007 03:44 AM
SRCIVIC05
Honda Civic (2001 - 2005)
Aug 10, 2006 06:26 PM
JDMStilez
Feb 4, 2005 04:46 PM
nelly6162
Jul 18, 2004 02:02 PM
rough_draft
Jun 4, 2004 03:20 AM
