Race Header, adding 'removable' cat?
Old Jun 17, 2008 | 11:16 PM
invisible's Avatar
Default Race Header, adding 'removable' cat?
I'm thinking about getting a race header for my k-series but worried about the inspection visual test. If you don't know, a race header eliminates the cat. I'm in Texas and they just do a visual look for the cat, no sniffer for obdII cars.
So I was thinking about say adding flanges to where I can install the stock cat back on when its time, then put a straight pipe back in after wards.
Is this too much than it's worth? Would this work? If so, whats an average price to pay? Just a idea that popped into my head, probably has been done before
Not sure if this is the correct forum, but move if it's not.
Old Jun 17, 2008 | 11:50 PM
NTCustoms's Avatar
you won't be able to use the stock cat because of how long it is. so buy a magnaflow one, and add a donut/slip flange on the header side (primaries) and a regular flange on the other side should be fine. spring bolts for the donut/slip flange should allow for enough flexing.
Old Jun 19, 2008 | 12:48 PM
kommon_sense's Avatar
Default Re: (NTCustoms)
why not just get a custom cat to fit in with your race header.
http://www.sms-products.com
You can get any diameter you need... any length you need... as well whatever flanges you need.
Old Jun 19, 2008 | 09:51 PM
wantboost's Avatar
Who is Mr Robot?
a guy sells round catalytic converters on ebay, i think i paid 40 bucks for my 3"
but he has them in different diameters, ceramic cores
you find one the same size as your header.. and use v-band flanges.. loads quicker and eliminates the time needed to line the flanges up and suck
Old Jun 19, 2008 | 09:54 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: (wantboost)
http://cgi.ebay.com/2-5-Cataly...wItem
theres one
and this one has an o2 bung in it (for the secondary o2, saves some hassle)
Old Jun 23, 2008 | 09:17 PM
ssmdc2's Avatar
Why not just weld little tabs to the header so you can bolt on the factory cat heatshields so it looks like there is a cat. Or you can cut a cat in half down the length and weld it to the header without cutting the header at all. I mean it's all visual right?
Old Jun 23, 2008 | 10:45 PM
nateg's Avatar
Default Re:
Old Jun 23, 2008 | 11:47 PM
NTCustoms's Avatar
yes
Old Jun 24, 2008 | 12:01 AM
wantboost's Avatar
Who is Mr Robot?
Provehito In Altum... Launch forth into the deep... or. reach for the heights
yay for latin class, lol
Old Jun 27, 2008 | 02:41 PM
2stepEK's Avatar
Former Vendor
Default Re: Race Header, adding 'removable' cat? (invisible)
Vband it
RomesEM1
Apr 14, 2010 12:16 AM
GSRkid123
Feb 28, 2008 04:10 AM
sane 007
14
Dec 6, 2004 02:14 PM
jeremy.
Nov 10, 2003 10:41 AM
