96 prelude cranks starts and stubles off
Old Jun 17, 2008 | 05:21 PM
ivredrider's Avatar
Default 96 prelude cranks starts and stubles off
96 prelude si starts and stubles out. like a main relay problem but not, it kinda runs a little longer than a main relay issue. replaced it anyways to be sure. checked ignition switch its ok. have fuel pressure with key on and while cranking and spark. car was towed to me with a blown engine, i replaced engine with reman. has 210 compression, triple checked cam timing, ok. ideas??????????
Old Jun 17, 2008 | 05:37 PM
Acidcrakker's Avatar
Default Re: 96 prelude cranks starts and stubles off (ivredrider)
Timing and or ignition.
Old Jun 17, 2008 | 07:36 PM
mattsnooz's Avatar
Bye an FPR with guage or pressure guage. monitor your fuel pressure when it stubles to a stop. If the fuel is dropping as its stumbling to a stop, that isolates it to a gas problem. If it stays strong around 40 (depending what test method you do 38 and 46 I believe) than its probably electically related.
Edit* I forgot to say you'd probably need a friend to help you with the fuel pressure check. Its nice to have someone in cockpit to start if for you and even give it gas to keep it going if that works.
Can you give it gas to keep it idling?
Old Jun 18, 2008 | 08:55 AM
ivredrider's Avatar
Default Re: 96 prelude cranks starts and stubles off (mattsnooz)
i have about 41 psi key on, then while cranking and when it starts for a second the fuel pressure drops about 5-6 psi and goes back to 40 which is whats it spose to do. its gota be electrical then i guess, but what..... ****!!!!!
svenglass
May 15, 2017 02:45 PM
blk007
Jul 10, 2007 05:56 PM
toyorotor
Jun 13, 2005 01:31 PM
crexer
Jun 8, 2003 07:51 PM
