electrical problem with h22 but good battery and alternator?????
Old Jun 17, 2008 | 02:29 PM
darockstar's Avatar
Default electrical problem with h22 but good battery and alternator?????
my car dies from no electricity like a bad alternator would do but the alternator is good...battery starts car but alternator doesnt charge it
this happened with another h22 i had. i took it to a place and i think the guy was messing with some stuff maybe wires near the fuse box inside the car. im guessing its something thats disabling the alternator even though its good?????
any help???
Old Jun 18, 2008 | 03:59 AM
AmauryR's Avatar
Default Re: electrical problem with h22 but good battery and alternator????? (darockstar)
just for ha-ha's, disconnect your a/c relays one by one (condensor and compressor I think is the second). Had the same issue with my prelude, turns out one of the a/c relays was shorting out internally causing a draw. randomly found someone on h-t who had the same issue.
Old Jun 18, 2008 | 05:11 AM
subydoored's Avatar
Default Re: electrical problem with h22 but good battery and alternator????? (AmauryR)
have you checked the driver kick panel for a blown fuse it controls the alt. its a 7,5 amp fuse usely blows when some one mess with a ground wire or loose wire happen to me it was a melt o2 sensor wire.
Old Jun 21, 2008 | 10:38 AM
darockstar's Avatar
Default Re: electrical problem with h22 but good battery and alternator????? (subydoored)
turns out it was a bullshit alt. pep boys gave me you know the ones that are 100% tested and guaranteed
Old Jun 22, 2008 | 03:35 AM
subydoored's Avatar
dont go to pep boys for to napa they have lots prelude stuff in stocl or atleast mine does. i know you can get intake gaskets fel pro doesnt make them. and e braqke cable got be factory order.
Old Jun 25, 2008 | 08:12 AM
bubxba's Avatar
i need to revive this thread cause my prelude is ahving the same problem and i know its not the alternator, so what is this driver kick box or whatever? im so stumped on this problem, i jsut want my battery to charge pleaseee help.sorry to sorta jack the thread
Old Jun 25, 2008 | 10:22 AM
subydoored's Avatar
Default Re: electrical problem with h22 but good battery and alternator????? (bubxba)
ya the driver kick panel
Old Jun 25, 2008 | 02:15 PM
bubxba's Avatar
where is that located?
Old Jun 25, 2008 | 02:51 PM
bubxba's Avatar
by kick panel do you mean like where the fuses are under the dash? and if so waht do you want me to check about it?i checked all the fuses.
Old Jun 25, 2008 | 08:35 PM
bubxba's Avatar
please help need to know asap.
Old Jun 26, 2008 | 05:04 AM
subydoored's Avatar
driver side under the dash next to the clutch pedal.there fusesyou need to check.
Old Jun 29, 2008 | 11:51 AM
darockstar's Avatar
the fuse box under the hood take it off and check the connections on the bottom...have you tested the alt? other than that check the wires that run on the alt
Old Jul 5, 2008 | 05:50 PM
Bernod's Avatar
I have this issue now as well. I will trouble shoot the Lude tomorrow to see what I find. This thread has helped me a lot. I'm a RX7 guy that has no RX7 so my Lude is doing it for me and it's doing a GREAT JOB!
Old Jul 7, 2008 | 11:40 AM
Bernod's Avatar
Found the problem. I originally thought the battery was dead and to make a long story short. The alternator was tested and passed however it was the problem after further testing and NOW no problems!
Lance Baker
Honda CR-V & Element
Dec 5, 2021 06:55 PM
EG_SICKZ
10
Jun 14, 2012 01:45 AM
drewby230
18
Aug 3, 2011 11:45 AM
phase7
Feb 20, 2007 07:16 AM
O16581724 5 2 5
Jun 26, 2006 03:57 PM
