Wont start
Old Jun 17, 2008 | 12:35 PM
civicmidwest_08's Avatar
Default Wont start
Alright I got a 1991 Civic 1.5 DP injection. The timing belt jumped and wasn't driven since than. I put on a new belt, lined up the top timing gear(the up mark is straight up) as with the key on the harmonic balancer(straight up as well), I replaced my rotor as that was damaged, and that is set to the number one cylinder. It turns and turns but wont fire up. I checked fuel pump, it wasn't kicking in. I replaced the main relay and now it kicks, I checked at the fuel filter and it has pressure, and is getting fuel properly. There is spark in all cylinders, and there is compression. Fuses are all good as well. Any other ideas?
Old Jun 17, 2008 | 12:48 PM
sgallagher's Avatar
Default Re: Wont start (civicmidwest_08)
You say there is compression? Did you actually test it? Ignition timing correct? Make sure your timing belt is installed and timing is correct.
Old Jun 18, 2008 | 12:24 PM
Okay, I'm getting a compression tester tonight, am I right about where the top timing gear and harmonic balancer key are supposed to be?
Old Jun 18, 2008 | 02:08 PM
cr-x-91's Avatar
just do it old school...get #1 cyl to top ded center, then align cam to head. make sure ur rotor is pointing to #1 plug and it better fire. U have fuel and spark, its timing.
Old Jun 18, 2008 | 03:05 PM
Okay there's compression. And that is all aligned right. It still won't start. I did some more research. I'm going to uplug the map sensor and see if that starts, that should tell me whether thats ok or not. And if that's not it I guess I'll hook a noid light to the fuel injectors.
Old Jun 25, 2008 | 01:10 PM
949's Avatar
949
i too have this same issue. but mine was becuase i took out the engine and got the engine built.
someone told me it might be my timing. how do it re do the timing. i have never done this before.
thekeysarebroke
15
Oct 1, 2012 05:35 AM
sd619jef9
18
Aug 25, 2012 10:35 AM
danitoxgc
Sep 16, 2010 12:40 PM
jdm27ef
Jun 29, 2008 06:38 PM
GroundZer0 336
13
May 24, 2004 09:27 PM
