Code 14 and 41, Causing bad gas mileage. LOOK HELP!!
Old Jun 17, 2008 | 11:58 AM
bigizsosexy's Avatar
Default Code 14 and 41, Causing bad gas mileage. LOOK HELP!!
I have a b16a2 in a 97 del sol.
I am currently throwing code 14 IACV and 41 Primary O2 Sensor, I AM GETTING terrible gas mileage could the o2 be the problem? or is it more than that?
Old Jun 17, 2008 | 12:07 PM
Default Re: Code 14 and 41, Causing bad gas mileage. LOOK HELP!! (bigizsosexy)
Also cat is rattling like a ***** on the corner I heard this could be the bad gas mileage problem as well.
Let me know please
Old Jun 17, 2008 | 12:19 PM
Iceman05's Avatar
the bad O2 sensor is causing your crappy mileage. The IACV will just cause surging and rough idle
Old Jun 18, 2008 | 12:55 PM
Default Re: (Iceman05)
k tomorrow i am going to get a stock beseries mani and I ll report back after its installed.
Thanks
Old Jun 19, 2008 | 08:05 AM
Default Re: (bigizsosexy)
question for you guys, should I get a o2 bung welded into my existing manifold or should I got one with one already in it.
The one i have now has a secondary only before the cat at the end of the manifold where it meets the cat, now I need one with both one in the top of the manifold and one in the end before the cat correct? and if so which mani should I go with i have a b16a2 in the car.
Old Jun 19, 2008 | 10:51 AM
Bump
ftrms
Oct 28, 2008 02:15 PM
96WhiteOnBlack
Feb 11, 2008 02:55 AM
HipHop Head
Jan 8, 2005 02:03 PM
d8168055
Feb 28, 2003 09:15 AM
SimonsTeg
Sep 13, 2002 03:26 PM
