Lexus IS-F
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 137 »</TD></TR><TR><TD CLASS="quote">http 404 - beauty not found...</TD></TR></TABLE>
click flickr link in sig. jeez.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RotiEatter »</TD></TR><TR><TD CLASS="quote">I messed around with one a couple weeks ago on my bike on the way home from work. Such a beautiful car in person. </TD></TR></TABLE>
X2
Pics do this no car no justice
X2
i'll take one in black, thanks
What does the "F" in the name of this new four-door, 416-horse velocityraptor from Lexus stand for? Company boss Jim Farley doesn't much care. "Maybe 'Fuji,' our racetrack," he says (the F logo is shaped like Turn One). "Or 'Circle-F' [the original code name for Lexus Division]. Or 'Flagship.'"
Allow us to offer a suggestion, Jim: "Fenomenal."
Based on the platform that underpins the IS 250 and IS 350 sport sedans, the IS F is a carbon-spewing, tire-vaporizing mutant, the gentrified Lexus family's black sheep (and you know how much fun black sheep can be). Given Lexus's carefully cultivated reputation for civility, the rip-snorting IS F shouldn't even be here. And yet, by sheer force of will (see sidebar), it is. Lucky us.
For sure, nothing else in the Lexus stable has the IS F's street-bruiser look. Two inches wider up front than the IS 350, the F also sports a larger grille (improved engine cooling), fat brake ducts in the front air dam, 19-inch, dark-gray BBS forged-alloy wheels, quad tailpipes in a dual stacked array, and a pronounced hood bulge that hints of something menacing lurking underneath.
It's in there. The engine, based on the direct-injection 5.0-liter V-8 that serves in the LS 600hL, was codeveloped by Yamaha; it's upgraded with new high-flow heads, hollow cams, a head-scavenge oil pump (to help maintain even lubrication during high-g loads), titanium intake valves, a dual-inlet air intake (the second intake opens at 3600 rpm for enhanced high-rpm breathing), and other performance goodies. The net result is 416 horsepower at 6600 rpm and 371 pound-feet of torque at 5200.
The IS F doesn't offer a manual transmission--and nobody's going to complain. Instead, standard is an eight-speed automatic with manual mode and paddle shifters. While the transmission uses a conventional torque converter in first gear, in manual mode the lock-up clutch remains engaged from second through eighth, directly connecting the engine's output to the rear wheels (lift off the gas, and the engine compression is immediate, as with a conventional manual transmission). Adding to the "manual" feel is ultra-fast shifting; Lexus claims the tranny can change gears in just 100 milliseconds--as quick as the Ferrari F430's F1 box.
From the company that's synonymous with a cloudlike ride comes a suspension that's as cushy as a manhole cover. Front spring and shock rates are up 90 percent; the rear rates have climbed 50 percent. Larger anti-roll bars front and back minimize body roll even more, as does a ride height lowered about an inch. Inside the huge forged-alloy wheels (said to be 40 percent lighter than cast-aluminum wheels of the same size) lie six-piston Brembo brakes up front (the vented and drilled discs are an inch larger than the IS 350's) and two-piston vented and drilled Brembo rotors (up 1.4 inches) at the rear.
If by now you think Lexus has forgotten everything it knows about coddling its buyers, the cockpit will immediately put your mind at ease. It's a racy place--shift paddles behind the wheel, four deeply bolstered sport bucket seats, oil-temp gauge, aluminized composite trim--yet it's still very Lexus. All the typical amenities are standard or available, including heated seats, navigation, Mark Levinson surround-sound audio, and radar-guided cruise. Our tester also featured the optional (and gorgeous) high-contrast interior, with dramatic white-on-black leather.
Acknowledging that their new IS F offers higher-performance limits than any public road can handle, the Lexus team unveiled their new black sheep at Laguna Seca racetrack. There, it took about, oh, two or three turns to realize the Nrburgring-tuned IS F is going to make serious trouble for the likes of the new BMW M3, the Audi RS4, and the Mercedes C63 AMG. The car is, quite simply, a monster: Acceleration is brutal, the brakes are wicked-strong, and handling grip is immense (a Sport mode for Lexus's VDIM stability-control system increases steering weight, boosts throttle response, and allows the tail to step out usefully before the electronics step in; Lexus says Sport produces faster lap times than switching off the system altogether). You could easily convince yourself you're driving a track car. The engine note completes the illusion. Given that Toyota runs its own F1 team, you expect the V-8 to scream like Jarno Trulli's single-seater. Wrong series. Instead, the IS F bellows like a Nextel Cup Toyota Camry (redline is a relatively low 6800 rpm).
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Alex_G »</TD></TR><TR><TD CLASS="quote">
I've seen a Black one & I thought the complete opposite...</TD></TR></TABLE>
same with the gunmetal one. Look good.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Alex_G »</TD></TR><TR><TD CLASS="quote">Wow the silver is a real let down.....
pictures dont do this car any justice.
SPORT INJECTION
Nov 8, 2002 05:00 AM
, really?
