Exotic Piston-Rod Combo: High End Pieces
Old Jun 17, 2008 | 10:52 AM
Rocket's Avatar
Default Exotic Piston-Rod Combo: High End Pieces
Prototype spy drawing for BVTEC Honda.
Here is the 2 gram version.
Click Me - 2 Gram Rod
Modified by Master of the Universe at 2:27 PM 7/17/2008
Old Jun 17, 2008 | 11:02 AM
EKhatch's Avatar
Default Re: Exotic Piston-Rod Combo: High End Pieces (Master of the Universe)
How much/any benefit in the skirt coming to a point vs. being straight across?
Old Jun 17, 2008 | 11:17 AM
Rocket's Avatar
Default Re: Exotic Piston-Rod Combo: High End Pieces (EKhatch)
It's the result of wieght reduction, removing all non-essential material.
Old Jun 17, 2008 | 11:45 AM
BMo Tuning's Avatar
STAR
Why are people still making **** fo da b series, k is da future y0!!
/sarcasmz
I like how the wrist pin has been moved to a higher location in the piston.
Who is designing this? Is it you?
Old Jun 17, 2008 | 11:47 AM
EatSleepJDM's Avatar
looks expensive
Old Jun 17, 2008 | 11:53 AM
Aquafina's Avatar
Looks light. Whats the wall thickness on the pin?
Old Jun 17, 2008 | 12:08 PM
Rocket's Avatar
Default Re: (BMo Tuning)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BMo Tuning &raquo;</TD></TR><TR><TD CLASS="quote">Who is designing this? Is it you?</TD></TR></TABLE>
Working with a CNC and metallurgy guru/genious. I provide input re key/critical design elements.
Old Jun 17, 2008 | 12:27 PM
lengualoco21's Avatar
The rod looks great. But it doesn't appear to be for an all motor application looks like its more for Forced Induction
Old Jun 17, 2008 | 12:41 PM
Rocket's Avatar
Default Re: (lengualoco21)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lengualoco21 &raquo;</TD></TR><TR><TD CLASS="quote">The rod looks great. But it doesn't appear to be for an all motor application looks like its more for Forced Induction</TD></TR></TABLE>
Yes, that's the FI version at 240 grams without bolts.
Old Jun 17, 2008 | 12:44 PM
SMSP's Avatar
Looks like a beefed up TRX bike piston with an aluminum rod. Nice pieces. But the real problem with the B is air flow.
Old Jun 17, 2008 | 01:02 PM
rebo0t's Avatar
hmmmmm
Old Jun 17, 2008 | 01:22 PM
flyrod's Avatar
Default Re: (rebo0t)
Looks pretty good! I wonder how well aluminum rods hold up for street or road-racing use? I think the top fuel drag guys replace them every few seconds... I remember reading something a while back about the aluminum rods help a bit with knock (or N20/-NO2 fuels) because the modulus is lower and the bearings don't get beat as hard with a "springy" rod.
Are these the same guys working on the aluminum roller-VTEC rocker setup?
Old Jun 17, 2008 | 01:26 PM
Combustion Contraption's Avatar
When aluminum rods first came around they were stricly race stuff. With the new stuff, and new tech, that really isnt the case anymore.
Old Jun 17, 2008 | 01:59 PM
UncleD's Avatar
Default Re: (Combustion Contraption)
Been trying to decide on what rods/pistons to use in my motor
Old Jun 17, 2008 | 02:15 PM
Big Teggie's Avatar
Good ****
Old Jun 17, 2008 | 02:24 PM
Dyno Dave's Avatar
I know you said that you had something special coming for my new road race
engine I hope this is a drawing of them
Regards Dyno Dave
Old Jun 17, 2008 | 02:27 PM
Rocket's Avatar
Default Re: Exotic Piston-Rod Combo: High End Pieces (Dyno Dave)
We've got a couple Aluminum alloys in mind. One is 50% stronger than 7075 series and the other is 100% stronger.
These alloys are already being used by some race teams.
Old Jun 17, 2008 | 03:30 PM
mar778c's Avatar
Community Builder
Community Influencer
Are you running a special set of oil control rings?
Also, you mentioned wieght reduction but you could not get the right performance and wieght reduction with a NiCrMoV alloy? Aluminum strength is tricky when it gets warm.
Old Jun 17, 2008 | 03:34 PM
Rocket's Avatar
Default Re: Exotic Piston-Rod Combo: High End Pieces (mar778c)
Not too concerned with high temp strength for the rod as the rod doesn't get nearly as hot as the piston.
For all out race we will skip using the 2nd ring.
Old Jun 17, 2008 | 06:37 PM
alterdcreations's Avatar
will the rod have a limited life expectancy or given the proper running conditions will it be sutible for a daily driver as a steel rod?
Old Jun 17, 2008 | 08:34 PM
Runnerdown's Avatar
Default Re: Exotic Piston-Rod Combo: High End Pieces (alterdcreations)
Great looking stuff. Low friction and light weight ftw.
Enough prototype pictures, lets have the real thing already!
Old Jun 18, 2008 | 03:29 AM
2stepEK's Avatar
Former Vendor
Default Re: Exotic Piston-Rod Combo: High End Pieces (Runnerdown)
Old Jun 18, 2008 | 04:10 AM
dyingwish's Avatar
Default Re: Exotic Piston-Rod Combo: High End Pieces (2stepEK)
Looks interesting, any peeks at the underside of the piston? Are these planned to be custom order only, as in built to spec?
Aside from further weight reduction, would having a gap in the ringland, just above the wrist pin lead to possible ring failure from vibration? I realize it isn't side-loaded in that direction, but just curious....
Modified by dyingwish at 5:32 AM 6/18/2008
Old Jun 18, 2008 | 04:35 AM
Wow thats light i would love to see an all motor rod if thats a FI rod. Are they still going to continue the I beam design or will you guys come up with a totally new style of beam.
Old Jun 18, 2008 | 07:04 AM
PirateMcFred's Avatar
Default Re: (Master of the Universe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Master of the Universe &raquo;</TD></TR><TR><TD CLASS="quote">
Working with a CNC and metallurgy guru/genious. I provide input re key/critical design elements.</TD></TR></TABLE>
Same guys doing the aluminum rockers? How are those coming?
