9,000rpm rev... Suggestions on head work??
Old Jun 17, 2008 | 10:36 AM
DB8_n_Ek's Avatar
Default 9,000rpm rev... Suggestions on head work??
I have a b16a motor in my Ek that is stock.. just the ecu is upgraded and it is a red ecu.. dunno what is done to the ecu but i know it goes up to 9,000rpm and it sucks a lot of gas... just wanted to get some suggestions on what head work i should do to it.. what kind of valve springs? Valve Retainers? Should I get New Exhaust and Intake Valves?? any suggestions??
Old Jun 18, 2008 | 04:22 AM
gibsanez's Avatar
Default Re: 9,000rpm rev... Suggestions on head work?? (DB8_n_Ek)
You should get a stock ECU because you're running a stock engine. All your doing is harm revving your stock engine to 9k even though it makes peak power at under 8k.
Old Jun 18, 2008 | 04:17 PM
SiRkid's Avatar
Default Re: 9,000rpm rev... Suggestions on head work?? (gibsanez)
I revved my b16head to 9k for a year and it was fine. though id minimally get some itr springs in there just to be safe.
Old Jun 21, 2008 | 09:54 PM
UJLSMoFo's Avatar
From: east coast performance and tuning, jacksonville, nc
Default Re: 9,000rpm rev... Suggestions on head work?? (SiRkid)
upgade the the valve springs and retainers . passed 9000rpms your asking alot of the stock retainer. i ve built a few circle track hondas and found these to be very common problem, but keep i mind these cars run 25 to 75 laps, pretty much wide open. as far as the valves, they hold alot i ve seen 700+hp cars with no problems.
Old Jun 22, 2008 | 11:40 PM
jakeiscool's Avatar
Banned
Default Re: 9,000rpm rev... Suggestions on head work?? (UJLSMoFo)
just because the computer lets the motor rev to 9k doesnt mean the bottom end, or the head can handle it.
Neckbeard
19
Nov 8, 2018 03:53 AM
I smell secretions
12
Feb 12, 2015 12:38 PM
champwhiteEG6
Sep 24, 2007 04:20 PM
dsadas89das78934
Oct 28, 2003 09:57 PM
