18volt Alternator output? Help?
Old Jun 17, 2008 | 10:04 AM
theelemental's Avatar
Default 18volt Alternator output? Help?
Hi Guys, I have a 1989 CRX with an obd0 B16, with a Obd1 conversion. I've driven it for 2 years swapped, and recently it had a starting problem. I jump-started it and tested the current at the battery while running, and it slowly climbed from 17.8 to 18.04 volts. Is this a need for a new alternator, or possible fuse problem, etc?
Thanks in advance.
-Matt
Old Jun 17, 2008 | 10:06 AM
dr_latino999's Avatar
Default FV-QR
Sounds like the voltage regulator inside the alternator went kaput, I had this problem a few weeks ago and it spiked to 25 volts which was not very nice to my wiring.
Old Jun 17, 2008 | 12:57 PM
sgallagher's Avatar
Default Re: 18volt Alternator output? Help? (theelemental)
I agree, your alternator is no bueno. Get that thing out of there BEFORE you start burning up wires and blowing fuses.
Old Jun 17, 2008 | 01:07 PM
stocker2shocker91's Avatar
I requested a short story for a title.
Default Re: 18volt Alternator output? Help? (sgallagher)
change it out asap, when mine went bad one night i just happend to have my high beams on and they both blew out...
you could get it rebuilt also that might be a little cheaper, it was only about 100 to have mine redone and that included, stator,brushes,rectifier,regulator and bearings. good deal i thought
driving home with just yellow fogs sucks
eggie75
Mar 25, 2010 04:37 PM
hondastrtracr
16
Jan 27, 2008 09:16 PM
JDMCRXTypeR
21
Dec 6, 2004 03:33 PM
