4th gen short ram intakes.
Old Jul 17, 2002 | 04:10 PM
psyphre's Avatar
Default 4th gen short ram intakes.
If I put the battery in the trunk do you think a 5th gen short ram would fit? Or is the car just not wide enough?
Old Jul 17, 2002 | 04:32 PM
Martaigne's Avatar
Default Re: 4th gen short ram intakes. (psyphre)
Custom mandrel bent piping.
Old Jul 17, 2002 | 04:50 PM
Sillypuddy's Avatar
I got an extra 3" U bend you can use if you want to buy it =P
-joe
Old Jul 17, 2002 | 05:00 PM
Gennady's Avatar
New User
A 5th gen short ram should fit with your battery still there. I dont think they are any longer. Only problem might right shock tower clearance.
Old Jul 17, 2002 | 05:41 PM
psyphre's Avatar
Default Re: 4th gen short ram intakes. (Wont be beat)
the filter box sits behind the battery in the 4th gens and it sits beside the battery in 5th gens. so if i get the 5th gen intake and remove the battery it should fit right?
Old Jul 17, 2002 | 05:45 PM
Gennady's Avatar
New User
Like I said, the only clearance problem might be with the right shock tower. But if your removing the battery all together, why not get a CAI?
Old Jul 17, 2002 | 06:01 PM
psyphre's Avatar
I want to do a cold air box setup. plus the short ram is only 100 bucks canadian.
Old Jul 17, 2002 | 06:59 PM
Gennady's Avatar
New User
So? A cold air would be like $200 Canadian. No big deal.
Gennady, who bought his short ram for $30 US.
Old Jul 17, 2002 | 07:02 PM
psyphre's Avatar
AEM's are 350 up here. the OBX's are 250. I'm going cheap cause the motor is getting swapped out and then turboed over the winter/spring.
Old Jul 17, 2002 | 07:18 PM
Gennady's Avatar
New User
Every single part that you need for a custom CAI minus the bpv will run you $50 US. Including piping, filter, clamps, rubber grommets, hacksaw, ceramic paint, and newpapers to paint it on.
ezol
Mar 4, 2007 09:02 AM
FifthGenVTEC
Jan 23, 2003 04:54 PM
Starrman85
Jan 15, 2003 04:30 AM
VRGNCD5
Oct 28, 2002 06:30 AM
