B head flange solidworks drawing
Old Jun 17, 2008 | 09:03 AM
dfoxengr's Avatar
Default B head flange solidworks drawing
INTAKE FLANGE
does anyone have a file for one? I am trying to design some ITBs and need one.
the dwg on t3 flange.com doesnt import correctly and has geometry errors in solidworks.
thank you
-derek
Modified by dfoxengr at 4:54 PM 6/20/2008
Old Jun 18, 2008 | 06:27 AM
dfoxengr's Avatar
Default Re: B head flange solidworks drawing (dfoxengr)
anyone? im not trying to sell flanges, just want to prototype an ITB setup that may be sold at one point pretty cheaply.
Old Jun 18, 2008 | 04:26 PM
gtconcepts's Avatar
If u have solidworks why dont u juts buy a gasket and make the drawing ?
Old Jun 18, 2008 | 05:00 PM
dfoxengr's Avatar
Default Re: B head flange solidworks drawing (gtconcepts)
why waste 10 bucks and an hour?
Old Jun 18, 2008 | 05:05 PM
k24em2's Avatar
Cause it's only ten bucks and an hour
Old Jun 18, 2008 | 05:07 PM
dfoxengr's Avatar
Default Re: B head flange solidworks drawing (k24em2)
thats a lot when someone is sending me one for free
Old Jun 18, 2008 | 05:38 PM
k24em2's Avatar
At least doing it yourself you know how accurate the drawing is.
Old Jun 18, 2008 | 06:36 PM
dfoxengr's Avatar
i need a visual, not a perfect to the 10th scale model here.
Old Jun 20, 2008 | 12:52 PM
dfoxengr's Avatar
bump
Old Jun 21, 2008 | 04:19 AM
dfoxengr's Avatar
bump...
Old Jun 23, 2008 | 08:15 AM
dfoxengr's Avatar
to the top
Old Jun 23, 2008 | 09:08 AM
FST GSR 1's Avatar
You are importing geometry from those AutoCAD files into SW?
Old Jun 23, 2008 | 09:26 AM
dfoxengr's Avatar
Default Re: (FST GSR 1)
yeah it turns out fine to look at, but when I go to extrude it, it has some geometry errors that I cant find to fix.
Old Jun 23, 2008 | 09:32 AM
FST GSR 1's Avatar
I know I looked at it in DWG editor quickly. AutoCAD files alwys translate into SW that way esp. on radi and tangent lines.
EDIT: Offset another plane at whatever distance, pick the entities one by one, careful not to double click. Convert the sketch onto the new plane. You can eliminate all the duplicate geometry this way and repair the sketch(tools/sketchtools/repairsketch), then extrude it.
Old Jun 23, 2008 | 12:58 PM
CarterRace.com's Avatar
I bet you already spent your hour and 10 bucks trying to find this for free...
Old Jun 23, 2008 | 01:44 PM
nowtype's Avatar
Default Re: (CarterRace.com)
The issue with the extrude is the fact on the top leftish corner of the flange there is an overlap on the lines thus making it not extrude properly. Fix is so it actually makes it a solid and you will be good to go. I'd suggest just tracing the exterior and extuding it. Probably take you 10 minutes. But any decent CAD draftsperson should have been able to figure that out already.
PS: I did this with another CAD program called Vectorworks, but it's all the same **** in the end.
Old Jun 23, 2008 | 05:02 PM
dfoxengr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FST GSR 1 &raquo;</TD></TR><TR><TD CLASS="quote">I know I looked at it in DWG editor quickly. AutoCAD files alwys translate into SW that way esp. on radi and tangent lines.
good idea, ill do that.<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nowtype &raquo;</TD></TR><TR><TD CLASS="quote">The issue with the extrude is the fact on the top leftish corner of the flange there is an overlap on the lines thus making it not extrude properly. Fix is so it actually makes it a solid and you will be good to go. I'd suggest just tracing the exterior and extuding it. Probably take you 10 minutes. But any decent CAD draftsperson should have been able to figure that out already.
PS: I did this with another CAD program called Vectorworks, but it's all the same **** in the end.</TD></TR></TABLE>
thanks for the insult but the way it came in there were more than one of those overlaps. im no pro user either, just alittle here and there.
Old Jun 24, 2008 | 04:19 AM
FST GSR 1's Avatar
Default Re: (nowtype)
Not really. What you see and what I saw will be two different things because we are both translating geometry into different softwares. but any decent CAD person should have been able to figure that out.
Old Jun 25, 2008 | 06:52 AM
dfoxengr's Avatar
bump
Old Jun 25, 2008 | 03:04 PM
BigMoose's Avatar
See if you can snag this file
http://home.windstream.net/erc...LDDRW
It was in my reference file folder. I have not built to this drawing and CANNOT verify that it is correct. Use at your own risk and with your own judgment. My Solidworks install is broken and I cannot open it... so I am not really sure what it is a file of!
Good luck.
Old Jun 27, 2008 | 09:14 AM
dfoxengr's Avatar
b ump
Old Jun 27, 2008 | 09:53 AM
legendboy's Avatar
haha an hour?? lol
Old Jul 6, 2008 | 07:13 AM
dfoxengr's Avatar
anyone?
Old Jul 6, 2008 | 05:53 PM
MAX_CFM's Avatar
are you looking for somthing like this?
Old Jul 6, 2008 | 05:54 PM
dfoxengr's Avatar
Default Re: B head flange solidworks drawing (MAX_CFM)
yes I am, could you please email it to me? possibly with the mounting holes also?
