Replacing Tilt Steering Column
Old Jun 17, 2008 | 08:07 AM
dr_latino999's Avatar
Default Replacing / Rebuilding Tilt Steering Column
I currently have well too much play in my steering, over 5 degrees left to right before positive movement is engaged. The steering rack was rebuilt last summer - Quaife Quick Ratio, and the u-joint connection to the steering rack doesn't have any play that I can feel. To "rebuild" the steering column proper, all I will need to replace #10 correct?
Old Jun 17, 2008 | 09:00 AM
jlicrx's Avatar
Default Re: Replacing / Rebuilding Tilt Steering Column (dr_latino999)
the only way you can get play in part #10 is if the u-joint in it is loose - otherwise, it has to be in the rack itself or in the tie rod ends
Old Jun 17, 2008 | 09:59 AM
Default Re: Replacing / Rebuilding Tilt Steering Column (jlicrx)
But what about the joint self contained within the shaft, is that impervious to failure?
fasterthanueg
Northwest (Sales)
Nov 30, 2012 11:28 PM
Mohsin
Oct 7, 2008 01:56 PM
RanCRX
10
Oct 9, 2007 05:44 PM
rotten
Oct 17, 2005 05:16 PM
