neep help building d16y8
Old Jun 17, 2008 | 07:45 AM
puthuff's Avatar
Default neep help building d16y8
i just bought a pNp head for my car and was wondering what cam to buy and also what pistons i should buy also and any other suggestions you might have
no turbo stayin all motor trying not to break the bank lol
Modified by puthuff at 11:52 AM 6/17/2008
Old Jun 17, 2008 | 07:49 AM
z6hatchboy's Avatar
Default Re: neep help building d16y8 (puthuff)
Depends on your budget and if your going turbo or n/a.
Old Jun 17, 2008 | 07:54 AM
puthuff's Avatar
Default Re: neep help building d16y8 (z6hatchboy)
right now i dont think im gonna turbo looking to spend somewhere around $1k
Old Jun 17, 2008 | 07:57 AM
1CaMw0nDeR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by puthuff &raquo;</TD></TR><TR><TD CLASS="quote">right now i dont think im gonna turbo looking to spend somewhere around $1k</TD></TR></TABLE>
Well just because "right now" you don't plan on going turbo, doesn't mean that "right now" you can't build it for "in the future"... You can have a fully built motor, and not be turbo, and still have satisfaction knowing that most likely the hardest you try to beat the **** out of it, it's gonna take the beating with a smile lol... You could get a complete bottom end kit "rods with ARP connecting bolts, pistons, rings, bearings, seals, head studs, head gasket, ect" for under a $1k for ur Y8"... Than in the future all you would need to do is invest in a decent little turbo setup and you're golden...
Old Jun 17, 2008 | 08:11 AM
puthuff's Avatar
Default Re: neep help building d16y8 (1CaMw0nDeR)
lol thanks for that info where is the best place to buy that kit?
Old Jun 17, 2008 | 08:13 AM
puthuff's Avatar
and also which pistons should i use ? what compression? etc
Old Jun 17, 2008 | 10:47 AM
1CaMw0nDeR's Avatar
http://fjdistributors.com/privacy.php Those guys are very reputable over on D-Series.org and were from what I understand, the first ones to have the custom D15B rods in stock for sale, because everyone was having issues using the D16Z6 rods in the D15 blocks "height purposes and such when matched with vitara pistons".. But yeah man you can do a Vitara Piston/Eagle Rod setup for well under $1k "plus the other components i listed above" and pretty much have a motor ready to handle whatever kinda forced induction you wanna throw at it... Nitrous, Turbo, Supercharger... I've tried all of'm and had best results with Turbo, mainly because if its not fast enough just crank that boost gauge up some more, re-tune, and your good haha... Nitrous I didnt like because it runs out to fast, Superchargers always seemed laggy on any civic/integra i've rode in, but Turbo's are just beasts... Plus Turbo's are made in a HUGEE variety of different sizes so say you have one to small, not making enough top end HP, just upgrade to a bigger turbo and you should be satisfied... Tuning is also a KEY FACTOR when you get into engine building... Just because the motor is built and capable, without tuning it you're not really doing much but just adding reinforcement.. You'll get better results after you're built no doubt, but unless you add in air/fuel components and tune it you won't be like blown away... Until you're boostin 20psi anyways haha... GL man
scallahan04
Mar 26, 2008 01:28 PM
UCNTCME
Jul 4, 2007 10:18 PM
Honda_Driver
Nov 13, 2005 10:37 AM
ExCon
10
Oct 14, 2005 11:09 AM
incertitude
Jan 14, 2004 02:03 PM
