PVC modifiactions? - B20 block...
Old Jul 17, 2002 | 03:45 PM
tinkerbell's Avatar
Default PVC modifiactions? - B20 block...
just considering the PCV system for my 2.0VTEC,
the B18/B20 block does not have the oil catch can like the B16 block - so doesnt have the huge hole that i think is for the condensed oil vapours to drain back into the block,
nor does it have the fitting at the top of the back of the block to pull the vapours through into the catch can.
do i drill and tap the back of the top of the block and fit a barbed fitting and then use a modified B16 catch can that has the big hole sealed over and a tap on the bottom like the Morrosso(sp?) unit?
any comments? other methods?
thanks,
t..
Old Jul 17, 2002 | 03:51 PM
jg's Avatar
jg
Default Re: PVC modifiactions? - B20 block... (tinkerbell)
Use the Endyn set-up. I hear it works pretty well.
Old Jul 17, 2002 | 04:04 PM
tinkerbell's Avatar
Default Re: PVC modifiactions? - B20 block... (jg)
hi, yeah,
i am in Australia - 'down-under' for some...
getting ANYTHING from the US of A is wayyyyyyyyyy expensive and takes too long...
so, yeah a clarification should have been that i dont want to buy an off the shelf item that i can make myself.
thanks for the tip though, ive just checked out their site and the $154 catch can set-up.
t..
turbo Si
Nov 11, 2005 06:36 PM
cyrix12
Sep 21, 2005 09:53 PM
onebad3dr
Nov 16, 2004 07:46 PM
integra6650
May 27, 2003 02:11 AM
