How to Make a Stripper Pole
Old Jun 16, 2008 | 03:29 PM
david@didrace.com's Avatar
Default How to Make a Stripper Pole
If any of the pictures don't load, hit 'Refresh' on your browser. Our web server sucks ***.
So we were having a group of 25 or so local Corvette club owners come by the shop last Saturday for an open house. We had them by last year and already dyno'd most of their cars so we had to think of some sort of entertainment. It took us about 10 seconds to decide that we needed strippers, lots of them.
Step one -
Order an inordinate amount of strippers to come to the shop. Done.
Step two -
Design stripper pole. From the weekend before while doing my preemptive research up at a couple strip clubs in Wisconsin I noted that having a polished metallic pole is a must. It also must be sturdy and hold up to 125lbs flinging around on it with over 1G over force at times.
So I hopped onto McMaster.Com to find the items I needed. Searching the term 'stainless tube' I came up with the pole material that I needed. 2" OD High Polish Type 304L Stainless Steel Tubing w/ a 1.87" ID leaving a .065" wall, six feet long for $87.68. I also ordered up a 3' length of the same material as the pole was to be roughly 8.5' tall.
I already had 1 7/8" 16ga 304 Stainless Steel tube for some exhaust I recently made.
All I needed was a base and top. Searching 'stainless fitting' I found #45605K656 which would be perfect to slip the ends of the 2" OD stainless into. McMaster Carr has a place within 20 miles of me so I called the next morning and picked up the materials from will-call. Total of roughly $185.
Here's the sketch of the bases -
I press fit a 5" length of the 1 7/8" OD tube halfway into the 2" OD 3' long tube and welded the two together. I then pressed the 6' length of 2" OD tube over the 2.5" of the 1 7/8" tube that was sticking out of the 3' section and fully welded the tubes together and made sure to have enough weld to grind down to a smooth surface with no low spots.
I then cut the 9' section to length and welded 6"x6" plates onto the bases. Drilled four 1/2" holes on each plate 1" away from each corner. Took out the hammer drill and drilled holes for the concrete anchor studs. I slipped the top and bottom plates onto the pole and slipped the assembly into position and bolted down the base plate. We then leveled the pole and attached the upper plate into the ceiling with lag bolts.
Here's the results, sorry some of the pictures are blurry... too many Monster Energy Drinks -
We needed a rug so we bought this sweet *** one the day of the event. $130 but so worth it.
And one of the 7, yes seven strippers we had there on Saturday. This girl took a Makita like a champ.
David @ DIDRace.Com
Modified by david@didrace.com at 6:38 PM 6/16/2008
Old Jun 16, 2008 | 03:40 PM
snowseeker's Avatar
Default Re: How to Make a Stripper Pole (david@didrace.com)
Most poles have bearings at the top and bottom for spin action.
Old Jun 16, 2008 | 03:49 PM
JRSC01GS-R's Avatar
Default Re: How to Make a Stripper Pole (snowseeker)
sounds like a good time indeed
Old Jun 16, 2008 | 03:56 PM
JDMCRX's Avatar
Default Re: How to Make a Stripper Pole (JRSC01GS-R)
Lol nice take it like a champ girl
Old Jun 16, 2008 | 04:10 PM
SD_Lurker's Avatar
HT White Ops
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by snowseeker &raquo;</TD></TR><TR><TD CLASS="quote">Most poles have bearings at the top and bottom for spin action. </TD></TR></TABLE>
Old Jun 16, 2008 | 04:16 PM
Default Re: How to Make a Stripper Pole (SD_Lurker)
Didn't have any complaints.
Old Jun 16, 2008 | 04:23 PM
weiRtech's Avatar
OG Fabricator
fewer pictures of the pole, and more of strippers.
Old Jun 16, 2008 | 04:58 PM
Dazed and Confused's Avatar
"Design stripper pole. From the weekend before while doing my preemptive research up at a couple strip clubs in Wisconsin I noted that having a polished metallic pole is a must. It also must be sturdy and hold up to 125lbs flinging around on it with over 1G over force at times."
Hilarious. I never thought I would see someone design and engineer a stripper pole on HT. I thought there would be more pics of the ladies tho
Old Jun 16, 2008 | 05:14 PM
bigsyke's Avatar
I had 3 in my old house, Ex wife was a stripper. I saw this I thought it was raining, but really it was my eyes watering.
Old Jun 16, 2008 | 05:51 PM
dave@passenger's Avatar
If you clean the scale off of the mild steel it will weld real nice and not toast your gas lense.
Where are the stripper pics?
Old Jun 16, 2008 | 06:08 PM
integraturbo96's Avatar
nice, I like that
Old Jun 16, 2008 | 07:26 PM
88ED8's Avatar
Default Re: (bigsyke)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bigsyke &raquo;</TD></TR><TR><TD CLASS="quote">Ex wife was a stripper.</TD></TR></TABLE>
Any pics?
Old Jun 16, 2008 | 07:41 PM
9295EJ-t's Avatar
should have left the tube unwelded.. that way the girls can spin easier... lol
there is a strip club near by, it has a spinning joint.. pretty fun watchin naked chicks spin around poles really fast!
Old Jun 16, 2008 | 09:38 PM
Finest's Avatar
No pics of stripper ON the pole? You're no good to me.
BTW, which clubs up here did you visit?
Old Jun 16, 2008 | 10:15 PM
bigsyke's Avatar
Default Re: (88ED8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88ED8 &raquo;</TD></TR><TR><TD CLASS="quote">
Any pics? </TD></TR></TABLE>
A ton. litterally 2000lbs+ of pictures. Iv been an enthusiast since 21. Then the sweet baby Jesus showed me the light
I wish I had some pics of my fireman pole I did. She wanted a 2 story setup like they have at deja vu. It was cool untill we had to sell the house. Best GF I've ever had. So much fun
Old Jun 16, 2008 | 11:05 PM
BbqEazyE's Avatar
haha that is probably the best post ive seen ina while. Nice pole man Thats also a pretty nice setup w/ the garage!!!
Old Jun 17, 2008 | 05:09 AM
littlemissy's Avatar
Default Re: (BbqEazyE)
You're saying that I didn't have to spend $350 bucks to get my mynx pole?! (although, mines removable)
Very nice thread. Love the pole you've made, are you planning on keeping it up? haha
Old Jun 17, 2008 | 06:58 AM
Top Ramen's Avatar
Default Re: (littlemissy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by littlemissy &raquo;</TD></TR><TR><TD CLASS="quote">are you planning on keeping it up? </TD></TR></TABLE>
That's the stripper's responsibility. . . .
Old Jun 17, 2008 | 07:01 AM
ROTARY's Avatar
Default Re: (Top Ramen)
^ lol
Old Jun 17, 2008 | 07:02 AM
b20turbojason's Avatar
Very nice work. Perhaps any pics of the pole in use.
Old Jun 17, 2008 | 07:17 AM
Kusai.Nihonjin.Desu's Avatar
If you can come up with a design where we don't have to tear up holes in the ceiling or the floor, I will buy it.
Old Jun 17, 2008 | 08:03 AM
Default Re: How to Make a Stripper Pole (b20turbojason)
Probably NSFW but no nudity - http://www.didrace.com/gallery...9.jpg
The rest of the girls didn't want their pictures taken, little did they know we have 15 high resolution security cameras.
Old Jun 17, 2008 | 08:22 AM
snootworks's Avatar
AWESOME! I've been grumbling about setting up a clandestine peeler operation at our shop for ages!
Hopefully your initiative in making it happen will be just the encouragement I need to get the rest of the gang on board. "Well OTHER shops are doing it now, so WTF?!"
Hehehe.
Old Jun 17, 2008 | 06:32 PM
2fast4u831's Avatar
I'm really 2slow
Default Re: How to Make a Stripper Pole (snootworks)
This thread is full of WIN!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Top Ramen &raquo;</TD></TR><TR><TD CLASS="quote">
That's the stripper's responsibility. . . . </TD></TR></TABLE>HAHAHA. fo sho!!
Old Jun 17, 2008 | 07:57 PM
alpha's Avatar
David. I have to ask. Do you have any job openings
Nice work, lol
