'91 Accord EX - Sunroof does not close all the way
Old Jun 16, 2008 | 02:56 PM
msnewman's Avatar
Default '91 Accord EX - Sunroof does not close all the way
I have a 91 Accord EX. I opened the roof and when I went to close it, it did not fully finish. Very small ~1/2" distance, but you can see the back of the roof has not fully lifted. It worked fine for years, and then all of a sudden this happened...I looked for debris or other obvious things in the track, but I don't see anything. I tried the manual nut under the plug in the headliner, but it still won't close. Any ideas? Thanks much!
Old Jun 16, 2008 | 08:33 PM
MN91CB7's Avatar
Default Re: '91 Accord EX - Sunroof does not close all the way (msnewman)
Could possibly just need to be greased. Mine didn't open all the way until I greased it. It could also be the start of a bad motor. Anyway, try properly greasing it, and see if that does any good.
Old Jun 16, 2008 | 10:20 PM
kleen98accord's Avatar
Check the are where the glass slides on. On my accord there was a metal piece that became loose and it stuck out, preventing the glass from closing all the way. Its held by a single screw.
Maybe that'll help.
Robert Lindqu
Jan 14, 2019 03:18 AM
808DA
Mar 17, 2009 03:47 PM
DilliPickle
Sep 22, 2004 05:39 AM
