CRX track times
Old Jun 16, 2008 | 02:20 PM
mugenteggy001's Avatar
Default CRX track times
hey guys. Picked up an abused 91 si from one of my buddies for uber cheap and i've made it my new drag toy. Therefore the gsr is now retired and will be the comfy dd. Anywho..........
91 CRX si with no passenger seat or rear interior
JDM b16a with pw0
Top Speed Pro1 1 piece 4-2-1 race header 2.5 collector
custom built intake by myself
2.5 crush bend exhaust back to a crappy ractive muffler
Ran at my local 1/8th mile and pulled a 8.78 @ 78mph on 1.80 60ft on 225 bfg dr's. Stayed consitnent 8.8-8.9 @ 78mph on 1.9-2.0 60fts. Should break the 13's in the 1/4 when i go later in the year.
I got vid i'll post later but just wanted post my results. I'm quite impressed to say the least for an abused bolt on b16. Thanks for any input guys.
http://www.youtube.com/watch?v=VEfkKOQrPnw
Modified by mugenteggy001 at 6:47 AM 6/20/2008
Modified by mugenteggy001 at 2:49 PM 6/28/2008
Old Jun 16, 2008 | 02:52 PM
onepoint6i's Avatar
Default Re: CRX track times (mugenteggy001)
you should hit around a high 13 or very low 14 with that eighth mile time..
Old Jun 16, 2008 | 03:06 PM
yeah given the mph and if the 60ft is still there it'll for sure do a 13.9 if not a 13.8. Of course it'll be a bit lighter before i make it to the 1/4 later this year so that should be easily accomplished. Just tryin to make up my mind if i want to just stay with the good ole reliable b16 bottom end or not.
Old Jun 18, 2008 | 04:20 PM
jarvis199's Avatar
Default Re: (mugenteggy001)
oh snap ryans taking over honda-tech!!!
Old Jun 20, 2008 | 05:46 AM
i don't know about that Jarvis but i am tryin to move up the n/a ladder. lol I saw your post on WVmotorsports by the way about your new tune. Sounds like you might getting that 8.3 you were lookin for.
Old Jun 28, 2008 | 01:49 PM
vid is up now on the bottom of the 1st post.
Old Jun 28, 2008 | 02:23 PM
wunfstgsr's Avatar
Loved
Community Favorite
Just wanted to ad my 1/8 mile time for my gsr, I just ran my car for the first time at qualcom's racelegal event lastnight with the hytech big tube replica and ran a best et at 9.634 at 74.13 mph header is untuned to the set up which is 11:6:1 comp., bc3+ cams aem 3" cai sk2 pro series man. portmatched to 68mm greddy sp2 catback whats your opinion on my times im not sure if this is a good # for a setup like mine like i said this was my first 1/8 mile drag race
Old Jun 28, 2008 | 07:23 PM
hmmmm....with that setup you should be able to dip into the 8's for sure. You're problem is that its untuned. You have a nice build thats capable of 190whp for sure but its not gonna run anywhere near like it should unless you get a good tune on there. What was your 60ft btw? With matching your e.t. with the mph i'm guessing probably around a 2.2-2.3? Just to give you an idea i have a 94 gsr with sri, knock off ebay 4-2-1 header, custom 2.5" exhaust and ud pulley. My best is 9.26 @ 77.8mph on a 2.201 60ft on street tires. Your setup is way more then mine and you should be able to trap around 81-82 mph with a good tune. Keep at it man you got alot left.
Old Jun 28, 2008 | 08:37 PM
wunfstgsr's Avatar
Loved
Community Favorite
The motor is tuned on hondata for my old setup which had a dc 4-1 w/sk2 test pipe i replaced it with the hytech big tube! its tuned to 204hp 148ft tq with the dc 4-1+sk2 test pipe! im throwing in sk2 pro1"s+ valvetrain and buddyclub spec 3 exhaust and gonna retune!
Old Jun 28, 2008 | 10:01 PM
wow it made 204whp. Either track elevation is way up or you must be spinning so badly that its dramatically effecting your traps. What exactly was your 60ft?
Old Jun 29, 2008 | 11:39 PM
wunfstgsr's Avatar
Loved
Community Favorite
First and second gear has massive wheal spin Tranny has Jdm 1st, 2nd & 3rd, 4.4 fd+lsd from jdm b16 4th and 5th from my gsr
Best ET:
0.850--Reaction time
2.331--60ft
74.13--MPH
9.634--ET
Best reaction time:
0.638--reaction time
2.396--60ft
74.13--MPH
9.727--ET
Modified by wunfstgsr at 12:46 AM 6/30/2008
Old Jun 30, 2008 | 05:45 AM
FST GSR 1's Avatar
Default Re: (wunfstgsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wunfstgsr &raquo;</TD></TR><TR><TD CLASS="quote">First and second gear has massive wheal spin Tranny has Jdm 1st, 2nd & 3rd, 4.4 fd+lsd from jdm b16 4th and 5th from my gsr
Best ET:
2.331--60ft
74.13--MPH
9.634--ET
Best reaction time:
2.396--60ft
74.13--MPH
9.727--ET
Modified by wunfstgsr at 12:46 AM 6/30/2008</TD></TR></TABLE>
No offense but that is just god awful. I used to pull 1.8-1.9 60's on 17" parada spec 2's on a bone stock DC2 chassis that weighed 2600lbs without driver (so 2800 with me) and ran 13.5's@104-105 all day with a single nozzle 65 shot out of the hole.
You need someone who understands how to launch and setup a fwd car to help you out at the track.
Old Jun 30, 2008 | 12:41 PM
wunfstgsr's Avatar
Loved
Community Favorite
Default Re: (FST GSR 1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FST GSR 1 &raquo;</TD></TR><TR><TD CLASS="quote">
You need someone who understands how to launch and setup a fwd car to help you out at the track. </TD></TR></TABLE>
Ya it was my first time draging like i said, the header isnt tuned so its throwing alot of things off its a big tube hytech replica but when the new set up is tuned i'll practice some more maybe a rev limiter and slicks will be in the mix next time i drag to bad i just got a reff ticket
Old Jun 30, 2008 | 03:01 PM
Well here's the only thing that doesn't make since. Even with changing to the big tube header i don't believe it would hender your car that much. Like i was saying your traps are about 8mph from what they should be and i just don't see a header switch causing that much of a difference. Your 60fts are avg for street tires so you're not spinning so badly that its affecting your mph. Only thing i'm thinkin is either the track you ran at has hella high elevation or you're very much taking your time shifting. There's just no way you should run that slow pulling an avg street tire 60ft with that setup if you really made a bit over 200whp, despite the header swap. But yeah definately get a retune and see what comes out of it. Also with your 1st tune did some one reputable and trustworthy tune your car? Just wanting to make sure you didn't get screwed or just lied too.
Old Jun 30, 2008 | 03:48 PM
jarvis199's Avatar
it could for sure be the big tube... they seem to kill power on setups under 2.0
Old Jun 30, 2008 | 04:30 PM
and why would you say that jarvis?? lol
Old Jun 30, 2008 | 05:09 PM
wunfstgsr's Avatar
Loved
Community Favorite
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mugenteggy001 &raquo;</TD></TR><TR><TD CLASS="quote">if you really made a bit over 200whp, despite the header swap. But yeah definately get a retune and see what comes out of it. Also with your 1st tune did some one reputable and trustworthy tune your car? Just wanting to make sure you didn't get screwed or just lied too.</TD></TR></TABLE>
Funny!! Actually Shawn himself from church automitive in long beach c.a did the tuning, he was pleased with the final tune he tuned it twice the second time i returned with rc 310cc injectors and sk2 test pipe and hit 204hp-148tq. i think i need much practice on launching and power shifting, I also think having a little under a 1/4 tank gas racing that night had alot to do with my motors performance when im low on fuel i feal a big diffrence in power & acceleration! i think it has to do with not enough fuel pressure, i had to go all the way home couse my window would not go up and fix it, i forgot to get gas on the way back couse i was running late and rushed for some reason maybe i was so eager to race for the first time at a track! but it was fun and hopefully i'll have a real good et #'s with the new setup and tune withe some practice of course peace
C_REX
82
Feb 18, 2005 08:01 AM
boonacka
27
Dec 14, 2002 10:47 PM
Black_eh2
Jun 2, 2002 08:44 PM
Rob!
Apr 30, 2002 06:10 PM
91ReXSI
Nov 12, 2001 04:00 PM
