2000 civic gsr, When going from a roll about 55-60 rpm then WOT car backfires then goes
Old Jun 16, 2008 | 11:42 AM
LastGenEK's Avatar
Default 2000 civic gsr, When going from a roll about 55-60 rpm then WOT car backfires then goes
I have a 2000 civic with a gsr mild build
81.5 wisco 9.1cp
scat rods SK2 IM
t3/t04e turbo running 275whp and 180tq @ 10psi
Precision 780cc
S300 from phearable.com
dyno tuned
When I stage before a pull about 2nd gear 40mph about 55-60 rpm and then jump on it it pause for a 1-1.5 seconds and backfires then will take off
Old Jun 16, 2008 | 12:35 PM
LST2's Avatar
Default Re: 2000 civic gsr, When going from a roll about 55-60 rpm then WOT car backfires then goes (LastGen
Maybe you need to adjust your throttle tip-in fuel enrichment.
Old Jun 16, 2008 | 01:13 PM
AdamB18C1EK's Avatar
call your tuner
Old Jun 16, 2008 | 01:29 PM
turbo-crx's Avatar
+1 on the throttle tip-in
Old Jun 16, 2008 | 01:30 PM
LastGenEK's Avatar
[QUOTE=LST2]Maybe you need to adjust your throttle tip-in fuel enrichment. [/QUOTE
Do I lower the % or raise it I dont have a Wide band so im not sure if it is lean nor rich?
Old Jun 16, 2008 | 01:31 PM
LastGenEK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbo-crx &raquo;</TD></TR><TR><TD CLASS="quote">+1 on the throttle tip-in</TD></TR></TABLE>
Cool thank you ill play with it
RACER69MAN
Sep 8, 2018 06:53 PM
hialeahzbg
59
Jul 6, 2006 12:12 PM
NA JDM GSR
Apr 24, 2006 09:14 PM
WONG FRIED RICE
Jul 5, 2003 08:13 PM
