Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
idle dip question Civic 01 Ex
Old Jun 16, 2008 | 10:37 AM
ejp2fast's Avatar
Default idle dip question Civic 01 Ex
I have a 2001 Civic Ex coupe, 130k. Whenever you are driving at normal speed say 55 and push the clutch in to pop to neutral, the idle dips down to about 550 rpm for about a half a second, then goes up to 1K ish. What is going on with this? Seems like it'll do it right after pushing the clutch in to neutral anytime when moving. Any suggestions on what this could be? Normal idle seems to be ok around 700. thanks.
Old Jun 16, 2008 | 03:57 PM
jedi03's Avatar
Default Re: idle dip question Civic 01 Ex (ejp2fast)
i have a dx that acts like its gna die when i stop...thinkin fuel or ground...i run a aem v2, full exhaust an suspension...run 91 octane chevron gas...will update if i find anything~
Old Jun 16, 2008 | 04:32 PM
oddmut's Avatar
do you have any vacumme leaks?
Old Jun 17, 2008 | 03:17 AM
skipbarber's Avatar
clean out your idle air control valve. take it off and blast it with some throttle body cleaner.
Old Jun 17, 2008 | 07:42 AM
ejp2fast's Avatar
Default Re: (skipbarber)
yeah, i had my haynes out last night, and thats what i will do, take the IAC valve off of the throttle body and clean that. plus i'll check for vacuum leaks.
thanks guys
Old Jun 18, 2008 | 12:23 PM
ejp2fast's Avatar
Default Re: (ejp2fast)
ok, last night removed the IAC valve and motor assemby and cleaned out that 'vane' with and it spun much much smoother. checked for vacuum leaks and nothing although i haven't put a gauge on it. got it all back together and it ran WORSE! called advance autopart and its like $285 new. any ideas?
Old Jul 1, 2008 | 08:05 AM
ejp2fast's Avatar
OK, here's an update. It did run a lot worse for about 50 miles or so, then cleared up and is fine. I think it was the coolant had to bleed itself and clear the system. As it is one of the highest points elevation wise for the coolant, this takes a little while. So, all i did was clean the IAC valve and that vane spun like a top when I was done cleaning it... all is good..
kaivorth
Apr 16, 2018 03:54 PM
hpiwinner
May 9, 2015 06:13 AM
LOL@hondas
Aug 13, 2010 11:21 AM
skyline35
Apr 8, 2008 05:02 PM
spoonraker
26
Apr 5, 2008 03:56 AM
